Page 1 of 1
cutting tool for 040 aluminum sheet
Posted:
Tue Feb 15, 2022 9:22 pm
by DesertApprentice
What is a good tool to cut 040 aluminum sheeting?
I see this aluminum cutting blade at home depot, looks like an overkill for such a thin sheet
https://www.homedepot.com/p/DIABLO-7-1- ... /305554862I was also recommended the diamond cutting blade
https://www.homedepot.com/p/RIDGID-5-in ... /312203593I am hoping there are some light weight options.
Re: cutting tool for 040 aluminum sheet
Posted:
Tue Feb 15, 2022 10:34 pm
by halfdome, Danny
I see you’re shopping for a Skill Saw blade.
I cut aluminum on a 10” table saw with a minimum of 60 carbide tipped saw blade.
If you want the safest and best cut go with a blade specifically for cutting aluminum.
Danny
Posted:
Tue Feb 15, 2022 11:09 pm
by mountainminded
A trim router with a bearing guided carbide trim bit is your lightest option. Clamp a straight edge to the material and run the router down the straight edge. Aluminum can ball up on the bit and there are ways to reduce this— lubricating the bit and slowing the speed (variable speed router or router speed control) are two I use. Keep the bit clean and you will get a nice cut.
Posted:
Tue Feb 15, 2022 11:15 pm
by tony.latham
For sheathing a teardrop cabin, I use a fine-toothed jigsaw blade and cut it about an 1/8" proud. Once the metal is in place, I use a flush-cut bit on a router to finish the cut.
Posted:
Wed Feb 16, 2022 10:00 am
by twisted lines
That Deoblo blade is a good one, ear plugs and sleeves are best used for this one.
Posted:
Wed Feb 16, 2022 11:01 am
by halfdome, Danny
For the radius I use pneumatic metal cutting shears leaving a small amount proud and finish up with a double flute flush router bit.
A bit with 2 flutes is important, less heat and a nicer cut.
Danny
Posted:
Sat Apr 02, 2022 11:39 am
by JasenC
I'd break it down with the skill saw and I tooth count carbide blade, then move onto the router for finales cuts like mountainminded suggested. This will give you much better control over your cuts and give you a cleaner cut as well.
Posted:
Tue May 31, 2022 7:20 pm
by flyguide
I used one of these. Cut close to what i wanted then used router to clean it up. Router will bogg down and not last tp last if you just try cutting thru everything.
https://www.harborfreight.com/14-gauge- ... tal+cutterhttps://fishbumfrank.com/teardrop/
Posted:
Wed Jun 01, 2022 11:26 am
by Graniterich
Me too, older version, works great
Sent from my KFTRWI using Tapatalk
