house paint on plywood skin
Finishes, paints and coatings
Postby cdlwingnut » Tue Oct 25, 2022 9:56 pm
The plans for the wonderer campers don't say how to seal the wood. I know fiberglass is one way but will caulking the seams then using house paint work to protect the wood.
also I have a lot of fabric left from my plane project that I could use to cover it with use that as a PMF
cdlwingnut
Re: house paint on plywood skin
Postby tony.latham » Tue Oct 25, 2022 10:24 pm
If you want to do it right, fiberglass/epoxy and use an oil-based paint. Otherwise, the plywood will probably check.
The P in PMF is a misnomer. The learning curve with the two systems are the same.
:thinking:
Return to Skinning secrets
