Finishes for ACX plywood and luan
Finishes, paints and coatings
Postby KBas » Mon May 27, 2024 12:12 pm
I'm new here to the forum and building a teardrop. I am amazed and overwhelmed at the amount of information available in this forum. What i am looking for is what to use to seal the wood and weatherproof this project, preferably in a simple process. The sidewalls are 3/4" ACX plywood, the front and roof are 5mm luan, and the rear panel is 1/2" ACX ply wood. I am sure that I need to apply some sort of sealer to the wood prior to painting and what type of paint would work the best. I look forward to hearing from you.
Karl
ps If you reply, please remember I am not yet familiar with many of the acronyms used here. Thanks
KBas
Re: Finishes for ACX plywood and luan
Postby tony.latham » Mon May 27, 2024 6:02 pm
Nothing seals wood as well as fiberglass/epoxy. The epoxy soaks into the wood and plasticizes it.
https://youtu.be/BJZYGY2he1o?si=au8e1htj1GsYzeMo
I suggest 6 oz cloth and recommend Raka for both the glass and the epoxy.
Epoxy needs UV protection, so either coat it with spar varnish or an oil-based paint
Postby Pmullen503 » Tue May 28, 2024 5:57 am
I agree, though epoxy is daunting and expensive, nothing works better.
The next best would be covering in canvas and paint.
The minimum I would recommend is the "The Mix". Thin oil based poly; 75% thinner/25% poly and give a good saturating coat, especially edges and let dry a couple days. Then repeat with 50/50, then 75/25 and finally 100% poly. Then paint. You'll still have to worry about joints opening up and water pooling, so be vigilant with maintenance.
Pmullen503
Images: 67
Postby Tom&Shelly » Tue May 28, 2024 7:55 am
For what it's worth, Shelly and I learned to use epoxy and fiberglass building our teardrop, and found it easy to use and very effective. We used Raka epoxy/glass and basically the system Tony describes.
Can't say much about other sealing systems such as "the mix" as I don't have much experience with it.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby tony.latham » Tue May 28, 2024 2:04 pm
though epoxy is daunting...
There are numerous videos on YouTube on how to apply fiberglass/epoxy.
https://www.youtube.com/results?search_query=fiberglassing+cedar+strip
I'm at the point where using fiberglass and epoxy isn't any more of a production than using varnish. Lay the glass down, mix a small batch of epoxy (using pumps), and apply it using a squeegee. It's just another skill.
Return to Skinning secrets
