I wasn't sure how the trailer would tow with our new van. We debated that leaving the bed in an UP position would put the extra weight at the top of the trailer and make it top heavy, but decided to give it a try and tow with it up. Although I could feel that I had more weight on the R side than on the L, the trailer tracked well. I was very please, no swaying issues, even when trucks passed me. The trailer doesn't have a V tongue, it has a straight one and I was thinking sway might be an issue, but as long as I keep my speed around 55 MPH, all went well. We will be adding some storage cupboards in the front V of the trailer yet, a fold down bench on the L wall, probably behind the axle so we have room to put a folding table thier for meals inside, on in climate days. I also want a small cupboard next to the compact kitchen. When traveling, our tandem trike, which weighs about 60 lbs will be strapped in on the L side of the trailer. The trike is 10 Ft long. That should help balance the weight out some, and if it is still not even, I can strap a couple. Gallon jerry cans of water on that L side too.
Still not use why our steel 6X 12 cargo trailer tracked so bad when we took the trike to the cycling trail last week. Mabe there wasn't enough weight with just the trike in it. I will have to do some experimenting around with that.
