what does everyone use for a tow vehicle.
Re: what does everyone use for a tow vehicle.
Postby guymi » Sun Oct 24, 2021 9:19 am
DSC02262 tt.jpg (183.5 KiB) Viewed 4392 times
Citroen C5 pour
guymi
Postby twisted lines » Sun Oct 24, 2021 10:52 am
My Wife's Highlander when she will let me ;)
Her Garage.jpg (165.95 KiB) Viewed 4377 times
Racking up; And Rapin foam
twisted lines
Postby TheOtherSean » Mon Oct 25, 2021 4:56 pm
I'm towing my tiny camper with a 1998 Ford E150 van.
TheOtherSean
Images: 111
Postby DairylandOverland » Thu Nov 04, 2021 10:04 pm
A 2019 Hyundai Santa Fe. 4cyl + awd = not a ton of power. It was definitely a factor in choosing the lightest 5ft wide teardrop I could find.
DairylandOverland
Postby Timmayy » Tue Nov 16, 2021 2:14 pm
So since our other old Plymouth wagon still needs a lot of work, my wife and I decided to buy another wagon that is more roadworthy for towing and other things.
Our 1967 Plymouth Fury III wagon. This winter I will be getting it ready for long trips next season.
67 Fury wagon 1.jpg (160.59 KiB) Viewed 4084 times
Timmayy
Postby pchast » Tue Nov 16, 2021 10:55 pm
Nice find!
pchast
Images: 97
Postby working on it » Wed Nov 17, 2021 11:10 am
Timmayy wrote:So since our other old Plymouth wagon still needs a lot of work, my wife and I decided to buy another wagon that is more roadworthy for towing and other things.
* I owned a sorta similar Mopar product from 69-71, when it got T-boned on an icy road by a '59 PINK CADILLAC (of all things). The Caddy backed-up and drove off, while I had a wheel stuck in a drainage culvert. I still dream of driving it, a 1967 Dodge Monaco 500 2-dr hardtop, with 383 4-bbl. + Torqueflite. Fast and comfortable, but having to service the drum brakes every other week (I was a young college student with a long commute) was its' only weak point. Wish I still had it. Enjoy yours!
173193172890148599
working on it
Images: 457
Postby Chief-John » Sat Apr 02, 2022 9:49 pm
My 2009 Scion 'XD' is a 1.8 liter Toyota 4 cyl with a 5 spd manual transmission. I was able to get 26mpg towing my 4x6 V-nose cargo trailer before the mods.
We've added 400# and 5 feet of length going from 10' and 760 lbs to 15' and 1000 lbs. The Beavers Bend gathering April 20th will be it's maiden voyage!
Chief-John
Images: 5
Postby Stealth TDI » Wed Jun 29, 2022 10:21 am
It's a pleasure to see other small cars towing their trailers! Now that I've spent a night in mine, officially making it a TTT, I finally feel worthy to share what I use to tow it:
2017 VW GTI with 160,000+ miles and tuned for power...
Stealth TDI
Postby SavageFen » Mon Jul 31, 2023 7:49 am
2015 Subaru Outback 2.5 four cylinder
SavageFen
Postby SandraMort » Mon Jul 31, 2023 11:19 am
I'm still planning but right now, my goal is a trailer light enough to pull behind my prius. However, I have two kids who drive and and my sister and her family live locally, so it's possible other folks might end up using it. That is, if I ever start (and finish) the project. For that, my husband needs to find a job. *sigh* At least the planning will take a while, so I've got something to do in the meantime. Hopefully, I'll be able to keep from perseverating about building it by using my time planning!
Sandra
SandraMort
Postby 48tinhouse » Sat Aug 12, 2023 4:39 pm
I tow our 1000lb '48 Modernistic teardrop with our '32 Ford (Chevy power) and sometimes with a 120hp, 6speed auto Ford Fiesta
48tinhouse
Postby gudmund » Thu Nov 23, 2023 10:16 pm
New '22 Chev Colorado 3.6L V6, 8sp-tran, 2wh drive with factory towing pk & brake controller = after 8500+ miles so far = 'GOOD'.... EPA MPG rated for 18city/25hy/21combined average - so far all MPG's have been right on the numbers++. First tow trip to N. Calif. in Sept.= 1765 miles/93.7gal = 18.84mpg (part of this trip included a good "up-hill climb" around the back side of Mt. Rainier). The PU has a max trailer tow weight rating of 7000lbs which I should be good on being my teardrop right now weighs in at 1900 total lbs. maxed out. (axle weight=1720lbs-toungue=180lbs.) which leaves me 'room' for some more add-on future lb. space if need be..... :thinking:
172720
Update - 2023/24 overall towing 'gas mileage' ? = a total of 5510 miles of towing ='s using 293.8 gals = 18.75mpg overall. One trip from here -W.Wash. to Kalispell, Mt.& back - included a total of going over 10/11 mountain 'E/W' (Cascade&Rockys) passes. Was also able to get one long steady 'freeway' run in getting a average of 19.3 mpg for almost 500miles (GrantsPass Ore/Stanwood Wa) heading home from Calif. on the last towing trip ... The PU so far? = I'm good..... with just over 20thou on it now & no problems to speak of, yet...........= it's been fine
gudmund
Images: 39
Postby tony.latham » Fri Nov 24, 2023 12:43 am
My trusty electric Tacoma.
And whatever you do... don't believe everything you read on the 'net. :?
Postby SLJ » Fri Nov 24, 2023 10:05 pm
Just swapped the Bronco Sport for a Maverick with 4K tow package. Planning on towing in some bigger mountains next year.
2021 T@B 320S Boondock
SLJ
