Plans/idea for teardrop design under 1,000 lbs
This includes traditional teardrop shapes and styles
Re: Plans/idea for teardrop design under 1,000 lbs
Postby Wendellnla » Fri Mar 24, 2023 9:51 am
tony.latham wrote:
By chance, are there plans available for that build?
Nope. But I built it with the same methods I wrote about in my book–-with the exception that the exterior sheathing is 1/8" Baltic birch, not the 1/4" I use in the book.
You'll find that .040 aluminum adds a lot of weight.
I looked up some weights of .032 and was surprised!
Guess I need to find some published data on weight per square foot the epoxy/glass adds to encapsulate the assembled cedar plank panels.
Wendell
Wendellnla
Postby Wendellnla » Fri Mar 24, 2023 11:01 am
Did your your sisters build use aluminum over 1/8 ply?
Wendell
Wendellnla
Postby tony.latham » Fri Mar 24, 2023 11:17 am
Yes.
Postby swoody126 » Fri Mar 24, 2023 3:54 pm
one element most folks don't know/understand it that the CLC design has no framing like most builds
their kits are composed of okoume plywood which is drop dead beautiful and as light or lighter than other species
if you get one of their precut kits the parts fit ... period
except for foamies i doubt you would be able to beat their weight
John brought one to the WoodenBoat Festival @ Port Aransas along w/ a plethora of his little boats and the finer boatbuilders were quite impressed
as mentioned above it would be best suited for one OR a young couple in the earlier stages of their relationship
BON CHANCE
sw
swoody126
Postby mountainminded » Fri Mar 24, 2023 4:37 pm
My 1947 Kit reproduction has a scale weight of 800#. That weight includes the rectangular steel grid frame, torflex axle and 15” wheels, original style fiberglass fenders, memory foam mattress, 2-burner stove and a SLA battery but does not include beer in the built-in ice box or water in the 5-gal onboard tank.
The galley on this early trailer design was quite simple and I think this is one area where modern builders get into trouble with weight— cabinets are really heavy. A simple design, even when solidly built, can still come in well under 1000#.
Last edited by mountainminded on Sun Mar 26, 2023 7:33 am, edited 2 times in total.
Cheers,
-Rob
168078
Rob Walker, Trailers4Two Bend Oregon
mountainminded
Images: 58
Postby pchast » Fri Mar 24, 2023 9:47 pm
Wendellnla wrote:
Where do I find this “list of completed campers” ?
I have poked around the forum a bit, but nothing jumped out at me. Thanks,
Wendell
Check out: viewtopic.php?f=2&t=56787
You can see the range of weight varies considerably. This gives you the opportunity to search for the lightest in a given size range. Then check the build log for the actual build parameters.
Have Fun,
Pete
pchast
Images: 97
Postby Wendellnla » Sat Mar 25, 2023 10:52 am
pchast wrote:
Wendell
Have Fun,
Pete
That’s a great resource, thanks!
I printed the pages, but the resolution makes it tough to read. Maybe just my old eyes.
Wendell
Wendellnla
Postby twisted lines » Sat Mar 25, 2023 5:28 pm
Number two is my plan.
Bought 1000 lb torsion axles :thinking: that should help.
Racking up; And Rapin foam
twisted lines
Postby pchast » Sat Mar 25, 2023 10:01 pm
Wendellnla
Put the posts into a spread sheet and you can easily blow them up and
follow the columns.
Pete
pchast
Images: 97
Return to Traditional Designs
