Widget Builders?
This includes traditional teardrop shapes and styles
Widget Builders?
Postby donkro » Sun Nov 13, 2011 11:02 pm
I'm wondering if anyone out there has built a Widget recently. I've built one teardrop and would like to build something a bit larger and would like to consult with someone who has built a Widget already. Thanks.
donkro
Postby Oldragbaggers » Tue Nov 15, 2011 9:49 pm
Check the Hall of Fame. I think Puffin is a Widget.
Becky
Life is sooooo good.........
Sail...camp....bike...repeat
Becky
Oldragbaggers
Images: 331
Postby aggie79 » Tue Nov 15, 2011 10:12 pm
The last one I remember was being built by Jeff (WarPony):
http://www.tnttt.com/viewtopic.php?t=24005&highlight=widget
I've seen it in person and it is gorgeous!
Re: Widget Builders?
Postby bobhenry » Wed Nov 16, 2011 8:15 am
donkro wrote:I'm wondering if anyone out there has built a Widget recently. I've built one teardrop and would like to build something a bit larger and would like to consult with someone who has built a Widget already. Thanks.
The widget and the vintage midget are close cousins. Although it may be tough to find a 1924 chervolet front axle or a model T gas tank as a water tank there are still a lot of great ideas in this old thread. I studied many of these old tutorials when I built Chubby and found that a lot of what worked then still works today. I think it would be fantastic to keep a new build as close as possible to the vintage plans especially the galley area. I learned something today looking over this design closely. See if you can find the flow thru ventilation system :thumbsup:
http://www.mikenchell.com/VintagePlans/pln_midgettrailer.pdf
Return to Traditional Designs
