by madjack » Tue Aug 11, 2009 1:52 pm
...my preference is take a piece like that and trim, what will be the down leg, 1/4-3/8th"s wide to facilitate bending...buy trim that is no more that 1/16th" thick...more than likely, the trim, will havvta be annealed...a de-tempering process in which a torch is used...if you use the "search" in the top index and enter "anneal" you will find a wealth of info on this technique and tips on bending...it is really not hard to do, a little practice and you will hve trim which will bend like buttah...........
