my electrical setup
my electrical setup
Postby myjeepcherokee » Tue Mar 15, 2005 6:08 pm
Thought I would share with you my electrical setup. This cabinet is where the majority of it is stored, the fuse panel and dist. block are mounted in the cabinet above. In this picture I have yet to hook up the second deep cell, but thats on its way. The power converter (green label) in this picture is a modified PC power supply outputting 6amps. The switch controls when it is on, and there is another switch (out of sight) that isolates the battery from it when it is hooked to 110v. The charger is a 2/4/6 amp charger with a battery charge level on it so I can keep an eye on the charge. Still need to loom some of the wire and clean it up a bit!
myjeepcherokee
Images: 20
My Gosh
Postby Guy » Wed Mar 16, 2005 1:28 am
Be Careful, you have sparks right above your battery which could offgas and cause a nasty fire.
Regards,
Guy
Guy
Images: 44
Re: my electrical setup
Postby bdosborn » Wed Mar 16, 2005 2:41 pm
myjeepcherokee wrote: In this picture I have yet to hook up the second deep cell, but thats on its way.
Hmmm, I thought you needed two new identical batteries when you wired them in parallel. That way one battery doesn't discharge the other. Are they 12V or 6 V batteries?
Images: 806
Vent
Postby Dee Bee » Wed Mar 16, 2005 3:04 pm
I'd still isolate the batteries in a case and vent the case to the outside just so a spark does touch off the gasses.
DEE
Grace happens...
Dee Bee
Images: 55
Re: Vent
Postby bdosborn » Wed Mar 16, 2005 8:43 pm
Dee Bee wrote:I'd still isolate the batteries in a case and vent the case to the outside just so a spark does touch off the gasses.
DEE
I think he did vent it. Check out the soffit vent to the right.
Images: 806
Postby myjeepcherokee » Thu Mar 17, 2005 6:28 pm
The case is vented, you can just make it out to the right in the picture. Also what you cant see is a blower fan that brings fresh air in from the outside on the left.
myjeepcherokee
Images: 20
Postby Johnee » Thu Mar 17, 2005 9:59 pm
What are you using for a breaker system on your 110 AC ?
Johnee
Postby myjeepcherokee » Fri Mar 18, 2005 8:32 pm
Johnee wrote:What are you using for a breaker system on your 110 AC ?
The 110v, never makes it past this cabinet. It is steped down by the power converter to 12v dc. Noting else runs off of it(well the charger), but the surge protector does hace a fuse and reset switch just in case.
myjeepcherokee
Images: 20
