Here is my trailer build thread which is based on Gadgetman's (I have no where NEAR his ability to make cabinets or a friend to work pro bono.) All this work was completed in a weekend since next week we will be camping at the Carlisle, PA swap meet. As a bonus, pretty much everything I had sitting around the yard. The requirement is to be able to 1- pull in a Jeep TJ (lifted/locked) or 2-get 4 Yamaha grizzly atvs to fit.
<edit 042713> Well, it looks like I skewed from gadgetman's floor plan/living quarters/cabinet ability just a "little bit."
![Thinking :thinking:](./images/smilies/econ_thinking.gif)
Anyway...
Base model Car Mate 8.5' x 22'
Twin 6000lb torflex axles
+ 6" height
+"get out door" on the opposite side
+4' v-nose for mpg/storage
Painted off-white/eggshell from the bare wood...
Railed both sides... 2 layers
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01608.jpg)
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01609.jpg)
Needed some storage... also ran 45ft of string LED light, for low amp. ext power needed...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01614.jpg)
Strap holder...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01769.jpg)
Ran a hard line out of 12/3 for the Honda generator, ran through the channel and custom tie down...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01767.jpg)
Tongue was 18" longer as per the sales rep since we had to worry about the tailgate vs the jack, now shortened to 6 inches, what a waste of 300.
![Sad :(](./images/smilies/econ_sad.gif)
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01765.jpg)
A leftover DiamondBack low profile cab guard from a Colorado works great for storage and as a the light control box...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01776.jpg)
A little red neck with the signal stick...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01781.jpg)
Needed more storage and the micro is mounted up...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01774.jpg)
Manual vent mounted 4ft from the back...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01770.jpg)
Powered vent 4 ft from the front...
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01775.jpg)
![Image](http://i119.photobucket.com/albums/o150/gregert12/toyhauler/DSC01778.jpg)
Linoleum the floor, 2qty, 8x12 sheets, perfect width, used carpet tape to hold it down.
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01798_zpsfa625d4a.jpg)
Picked up a 18"x24"x7' cabinet from Home Depot, "scratch and dent" for $150 w/ tax vs $220+. Had to rebuild the back since the staples came out, fix the broken slider drawer (bent wheel) ** to be minwaxed ** Really wanted a 24" depth.
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01799_zpsc7e5398a.jpg)
Secured it to the top with the 2x4 brackets (through bolted 2 per bracket, 4 brackets in all) and had it sit out from the "V" for the mini toilet.
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01800_zps2584fb2b.jpg)
Humm... How can I hide this and create privacy? I got it! Instead of bending rebar and welding brackets, I took a prebent piece of aluminum, 3 wire loom clips, an old bathtub privacy screen and bolted it in. Can't beat free.
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01801_zpsd97dc52e.jpg)
Curtain open..
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01803_zpsdd94c379.jpg)
Need a laptop tray for when we are in the back sleeping or outside it. Took a piece of scrap, cut it 17"x17", use 2 brass hinges and bolt it up.
Open------------
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01804_zps5c171e23.jpg)
Closed with a bungee----------
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01805_zpsd4ca23dc.jpg)
Current setup---
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01806_zpse5283c8a.jpg)
![Image](http://i119.photobucket.com/albums/o150/gregert12/enclosedtrailer/DSC01808_zps20941c1b.jpg)
To be finished...
minwax/seal cabinet
find a 12" wide cabinet, for by the door
find a counter top to span the door to the V nose
