"Hypno-Toad's Command Post." Door and windows in!
Re: "Hypno-Toad's Command Post." Let the skinning begin!
Postby Junkboy999 » Wed Nov 28, 2012 11:25 pm
For the price you can’t beat a simple Delta Contractor Table saw. I don’t like all the new plastic ones like
Ryobi and Dewalt. The Delta is simple and easy to trick out. This is mine all tricked out.
Link to my photobucket table saw folder.
http://s22.beta.photobucket.com/user/Pb ... 0759445223
I use same Rockler Twist Plus Link adjustable belt. best thing to make a saw run smooth. I did spend a
few $$$ on a used Incra Fence set up.
Junkboy999
Images: 52
Postby jeff0520 » Sat Dec 01, 2012 7:54 am
tat is an awesome saw table Junkboy! I wish I had room for something like that. My workshop is half of a 10 x 20 backyard shed, and a portable garage tent
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby cracker39 » Sun Dec 02, 2012 4:16 pm
jeff0520 wrote:that is an awesome saw table Junkboy! I wish I had room for something like that. My workshop is half of a 10 x 20 backyard shed, and a portable garage tent
That sounds a lot like my workshop. I'm using half of my 12' x 24 screened back porch for my workbench, storage cabinet/shelving units, drill press and bench-top band saw. My table saw sits on the open, but covered, end of the porch. My cut-off saw is under the portable garage behind the Pop Top where I used it last.
Dale
cracker39
Images: 233
Re: "Hypno-Toad's Command Post." Fiberglass body filler goin
Postby jeff0520 » Sun Feb 24, 2013 9:25 pm
It's been a busy weekend. Ive been putting in the fiberglass body filler.
102520
102519
102518
102517
102516
102515
102514
102513
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post." Fiberglass body filler unde
Postby jeff0520 » Tue Apr 02, 2013 6:33 pm
Not much new to report. Fill and sand, sand and fill. A friend of mine has a 10 year old daughter named Samantha. She has a very sharp interest in any sort of construction and buildiong project. The messier and more complicated, the more she is interested. The kid is born to be an engineer I think.
Well, There was a lot of filler to put in seams and screw holes in the roof, and she is a tiny thing, less than 50 pounds, so...
104112
She had a blast and it worked out very well :D
jeff0520
Images: 128
Postby jeff0520 » Tue Apr 09, 2013 8:46 pm
Finally had a day to work on the Command Post again! Got most of the first stage sanding done. anout 2 hours more and it will be done. Then I'll need to mix a little more body filler and hit the little voids and cracks that showed up, and do the final sanding.
104495
104493
104492
jeff0520
Images: 128
Postby jeff0520 » Fri Apr 12, 2013 5:12 pm
Woo Hoooo! First stage body filler and sanding done. Now just spot touch up with filler here and there,and a sand the touch ups, and it'll be ready for fiberglass :D
jeff0520
Images: 128
Postby down under tech » Fri Apr 12, 2013 5:41 pm
Hello Jeff: It is looking very good. I really like this trailer's style. I want to build one of these Squidgets too.
Keep going, It'll Get Done... :)
Johnny D.
"The Silver Nugget" Build
down under tech
Images: 571
Postby jeff0520 » Fri Apr 12, 2013 6:46 pm
Thanks. :)
It's a good design. Dale did a great job on the planning. I just needed to modify it a bit to fit a big ol' boy like me :D
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post." Putting on the fiberglass s
Postby jeff0520 » Tue Apr 30, 2013 10:25 pm
Well, my truck is broken down in the shop AGAIN.....So I guess it's time to work on the camper! :D
With the first planned camping trip 3 weeks away, It's about darned time I make some progress.
Just praying I get it campable in time :worship:
Fiberglassin' pics:
105679
105680
105681
105682
105683
105684
105685
105686
My expected help on fiberglass was unable to make it due to illness, so I had to do a two person job alone. As a result, my seams and overlaps are NOT as straight as I'd hoped, but they were the bast I could accomplish alone. :(
I'm hoping that paint will mostly make the irregular look go away.
jeff0520
Images: 128
Postby jeff0520 » Wed May 01, 2013 7:17 pm
WOO HOOO! very last top coat of epoxy applied. Just waiting on it to dry so I can put the Command Post to bed for the night :)
jeff0520
Images: 128
"Hypno-Toad's Command Post." Primer done, two coats!
Postby jeff0520 » Sun May 12, 2013 7:02 pm
Hello all,
I got two coats of primer shot today. The planned maiden voyage is in 8 days, so I've got a LOT to do!
106298
106301
106300
106299
I'm so glad I don't have to worry about UV problems with the epoxy any more :D
Once I get the white paint shot and dried, I'll get windows, door, and roof vent installed. Then I'll try ti get at least the rudamentery bed frame built so we aren't on the floor for the upcoming trip. There won't be time for electrical or anything like that.
jeff0520
Images: 128
"Hypno-Toad's Command Post." First coat of paint and a bumpe
Postby jeff0520 » Mon May 13, 2013 9:57 pm
Today I shot a coat of white. It needs a second coat for sure. I also got my long-awaited bumper assembly fit up. I need to tack a couple of temporary tail light attachment points on. for the camping trip next week I'm going to mount the cheap and crappy taillights that came with the harbor freight chassis to a couple of tabs made out of the harbor freight fender brackets. This is just to get it legal for the upcoming trip. Later I'll put tail lights on the flat spot on the back where they go.
106511106512106513106514106515106516106517106518
jeff0520
Images: 128
Re: "Hypno-Toad's Command Post."first coat of paint and a bu
Postby S. Heisley » Mon May 13, 2013 11:08 pm
You're getting there but you're right. You still have a lot to do.
It's looking impressively good, though. :thumbsup:
Wishing you sunny weather for your first trip. :goodmorning:
Postby jeff0520 » Tue May 14, 2013 8:20 am
S. Heisley wrote:You're getting there but you're right. You still have a lot to do.
Thanks! The forecast looks good so far :)
jeff0520
Images: 128
Users browsing this forum: Bing [Bot] and 10 guests
