rufi0h wrote:Thank you everyone for your replies. I am going to build the next ribs out of plywood and laminate them together. Now the hard part of trying to salvage my Aluminum that is stuck on there pretty well with contact cement.
If you use a good grade of 3/4" cabinet plywood there'll be no need to laminate. Quality cabinet grade plywood has 9-11 plies, all oriented perpendicular to each other. If you make each rib at least 1 1/2" deep (vertically) you'll have plenty of strength to avoid twisting, warping, splitting...
Carl's advice on removing the aluminum skin should work, just take your time.
As Aggie79 pointed out, building 'in place' if possible is good practice. If not possible, repeated dry fitting & using enough & correct fasteners to insure correct orientation of parts will make a big difference.
