Construction Photos
Postby rainjer » Mon Apr 10, 2006 11:03 pm
We have a floor. It is insulated with 1 1/2 foam. I just need to cut the foot well on top & undercoat & bolt down.
Pictures in the Album.
rainjer
King Koleman
Images: 11
Postby rainjer » Wed Apr 12, 2006 8:42 pm
We have a undercoated floor. :applause: :applause:
The only problem was, l forgot to drill my holes to bolt bown the trailer. :x :x :x
That will be the next "fun" thing to do when it dries. :thinking: :thinking:
rainjer
King Koleman
Images: 11
Postby madjack » Wed Apr 12, 2006 8:55 pm
...don't forget to goop up some stuff in those bolt holes too...after you clean it offa your drill bit................... 8)
Postby rainjer » Wed Apr 12, 2006 9:01 pm
I work in a machine shop, drill bits are not an issue...... :twisted:
I was going to run a bead of caulk between the floor & the frame. I will put some in the holes as I bolt it.
The part tha made me mad was I had got the floor lined up & squared up & crawled under it and marked all of them. How I will have to measure to locate them or drill thru both the floor & the frame.
rainjer
King Koleman
Images: 11
Postby Miriam C. » Wed Apr 12, 2006 10:25 pm
Rainjer, That is the best warning I have read in a long time. ;)
If you work in a machine shop you won't have a "bit" of trouble.
Miriam
Postby rainjer » Sun Apr 16, 2006 2:30 pm
I think I am committed. I have cut the sides.
Here you go Madjack.
rainjer
King Koleman
Images: 11
Postby madjack » Sun Apr 16, 2006 2:58 pm
...thanks for the photos...we do luv 'em ya know :D ;) :thumbsup: ......................................... 8)
Postby rainjer » Sun Apr 16, 2006 10:08 pm
The door is now cut out! :applause: :applause:
I had to clean up in a hurry. I will post pictures tomorrow.
rainjer
King Koleman
Images: 11
