New teardrop
New teardrop
Postby Fishingtomatoseed » Tue Jul 16, 2013 6:56 am
It is just in ink right now. Off to the AutoCAD to get it all drawn up.
Fishingtomatoseed
Images: 9
Re: New teardrop
Postby GPW » Tue Jul 16, 2013 10:26 am
Round nose eh ??? 8)
Re: New teardrop
Postby Fishingtomatoseed » Tue Jul 16, 2013 11:23 am
I like the way the Airstream Torpedo looks. And after watching you and KC put together y'all's foamy and hybrid builds. I think it will be constructed that way. I was going to give the fiberglass a go on finishing it out.
Fishingtomatoseed
Images: 9
Re: New teardrop
Postby TPMcGinty » Tue Jul 16, 2013 11:27 am
Looks like a Camp Inn Raindrop 560 Ultra. Here's the link:
http://tinycamper.com/raindrop560ultra.htm
Tim
TPMcGinty
Images: 146
Re: New teardrop
Postby Fishingtomatoseed » Thu Jul 18, 2013 8:05 am
It does look like. Almost to the point of me copying it. Well I guess this will be Clint's version. The one I am planing will be bigger. Standie with a recessed floor. I will try to get some rough drawings up this weekend.
Fishingtomatoseed
Images: 9
Re: New teardrop
Postby aggie79 » Thu Jul 18, 2013 8:48 am
Clint -
I'm itching to start #2 also. Have you seen this build of a Torpedo=based design: http://www.tnttt.com/viewtopic.php?f=50&t=51954 ?
Take lots of pictures.
Take care,
Re: New teardrop
Postby Fishingtomatoseed » Sun Jul 21, 2013 7:57 am
Tom,
I did see that one. It looks sharp and is part of my inspiration for this build. I would like to build this one all out of foam and fiberglass. May have to read the big foamy thread again to get ideas again.
Just wondering if any one knows off hand if fiberglass and foam stick good together? I know the last time I was reading in the foam section they where testing it.
Fishingtomatoseed
Images: 9
Re: New teardrop
Postby High Desert » Sun Jul 21, 2013 9:56 am
Clint, fiberglass will work! Mel used it on his Road Foamie build;
http://www.tnttt.com/viewtopic.php?f=55&t=45698&p=1022120#p1022120
look forward to watching your build of this design, should be sharp 8)
Shaun
High Desert
Images: 27
Re: New teardrop
Postby Fishingtomatoseed » Tue Jul 23, 2013 5:09 pm
High Desert wrote:Clint, fiberglass will work! Mel used it on his Road Foamie build;
On my list to read!
Fishingtomatoseed
Images: 9
Re: New teardrop
Postby KCStudly » Tue Jul 23, 2013 8:31 pm
Fiberglass reinforced epoxy and will work, although there was at least one report of problems with heat of cure being an issue. Others, that from what I gather have more practical experience, say that this should not be a problem at normal mix ratios and batch sizes.
Polyester resin based "fiberglass" will melt the foam.
Some people get kind of prickly if you just say fiberglass w/o specifying the epoxy resin, as this seems to default to the assumption that the resin is polyester.
I have used epoxy and glass over a blue foam mold for a small project and can confirm that these materials are compatible. :thumbsup:
