The biggest teardrop ever built?
Postby doris s. » Mon Jul 29, 2013 8:36 pm
So what's the size of the biggest teardrop ever built? I was thinking about building a cargo conversion, then I thought a standy would be great because I can make that lovely teardrop shape, however a standy won't fit through the garage door. So now I am thinking about a teardrop that is 7 wide, and 12 long. A 7 wide would allow for sleeping crosswise which would leave room for a sitting area and a porti-potty. Any one build a teardrop this large before? Would I need a double axle trailer?
Doris
doris s.
Images: 32
Re: The biggest teardrop ever built?
Postby pjo129 » Mon Jul 29, 2013 9:14 pm
Check out Joseph Hansen's 1963 BeeLine Foamie Hybrid. I'd link it in here, but I don't know how on the Tapatalk App. Just do a search.
Pete Olson
Newburgh, IN
pjo129
Images: 73
Postby toolman » Mon Jul 29, 2013 9:17 pm
Hi Doris,
I have no idea about someone building a TD of that size.
Whether you have a have a single axle or duel is the weight of what you build.
Just a guess, I'd say a single axle is good for about 1,000 pounds. Over that I'd say a duel axle would be appropriate.
Go to a place that sells trailer and ask them about the weight rating of various trailers, then you'd know for sure.
You'll have to figure out the weight of the items you are using to build and add to your unit to decide what you'll in the way of axles.
Jerry
toolman
Postby Fyddler » Mon Jul 29, 2013 9:30 pm
I started with a single axle boat trailer rated for just under 3K. Look at my build, although probably not considered a "teardrop". 12'x7', roughly based of Grant Whips "Campster 12" design. I have a queen bed that will convert to a dinette, and will have storage closets in the nose.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby mezmo » Mon Jul 29, 2013 9:55 pm
This ~7x12 TD was on reno CL in June:
renoCL3721063029 060713
107454
107453
I think it was also in one of the two TnTTT For Sale threads too
as a 'family size TD and a kit for another' or some such.
mezmo
Images: 194
Postby emiller » Mon Jul 29, 2013 10:04 pm
The Maxitear is the largest I have seen but then again when it gets that big it is a standie.
emiller
Images: 157
Postby CarlLaFong » Mon Jul 29, 2013 11:27 pm
My single axle cargo trailer has a 3000 # GVW. You don't need tandem axles
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby eamarquardt » Tue Jul 30, 2013 11:19 am
"Biggest Teardrop" sounds like an oxymoron to me.
Cheers,
Gus
eamarquardt
Images: 150
Postby Donutboy » Tue Jul 30, 2013 1:04 pm
doris s. wrote:...I thought a standy would be great because I can make that lovely teardrop shape, however a standy won't fit through the garage door.
With a dropped floor, you can create a standie that fits in the garage. I'm about 5 ft 11 and can almost stand in mine (I stoop slightly). My wife is about 4 Inches shorter and can stand up all the way.
Jerry
Retro-Kamper
(Puffin for Four)
Donutboy
Images: 126
Postby angib » Tue Jul 30, 2013 1:14 pm
As well as the Maxitear, there is also the 1935 Airstream design sold as plans:
angib
5000 Club
5000 Club
Images: 231
Postby 48Rob » Tue Jul 30, 2013 6:24 pm
Something of a can of worms...but define "teardrop". :dead:
Do you mean what is an official teardrop?
What is teardrop shaped?
What people call teardrops because they don't know or care? :thumbdown:
The largest production teardrop was the Fleet Cabin Car.
The largest homebuilt may be the Maxitear.
The largest teardrop if you don't know or care is anybody's guess as it could be anything from a bus to a trailer to a boat to an airplane...
Rob
48Rob
Postby Mary C » Tue Jul 30, 2013 7:15 pm
Doris, You can make it out of foam and won't have to park it in the garage and for up keep buy a gallon of paint. you can make it as large as you want. just a thought!!!
Mary C. :)
Mary C
Images: 473
Postby doris s. » Tue Jul 30, 2013 7:20 pm
Oh, you guys rock.
Great pics and ideas. Thanks.
I'm going to check out all the designs you posted.
Thanks,
Doris
doris s.
Images: 32
Postby Fyddler » Wed Jul 31, 2013 9:28 am
+1 on the drop floor, although depending on your trailer frame configuration this can be tricky. My drop floor isn't quite as deep as I wanted because supports for my young go all the way back to the main frame. I can just stand in mine at 5'11", and it just fits in my garage.
Fyddler
Postby JuneBug » Wed Jul 31, 2013 9:58 am
Doris, A garage-able standy design might be worth considering. There is one design that is tiny (built on a 6 x 4 trailer frame), very rounded, and amazingly has a kitchen, bathroom and full bed, but the kitchen is in the interior -- there is no hatch in the back. The plan uses a dropped floor pan to achieve a low overall height. I have the thread bookmarked on my home computer and will post it when I get home from work.
The Little Guy T@B has a version with rear kitchen, a la teardrop, but is not garage-able.
The design below (related thread is here) is also nice and more 'teardroppy' with a galley in back, but I don't know the overall height:
"The large print giveth; the small print taketh away" Tom Waits
JuneBug
Users browsing this forum: Bing [Bot] and 6 guests
