Staining the inside of my teardrop? Dangerous?
Postby tscarbroughdc » Wed Aug 28, 2013 9:56 am
Forgive my dumb question, but I am about to put the walls on my teardrop this weekend, but think that I may want to paint/stain the inside first...
Thus, my question...
Is there any danger to staining the inside of my teardrop? I mean, will the fumes kill us while we are sleeping in it one night? Will the stain make it more flammable?
Im just making sure so that my kids and I are safe! haha...
Thanks for your input!
tscarbroughdc
Re: Staining the inside of my teardrop? Dangerous?
Postby Greg M » Wed Aug 28, 2013 11:06 am
No danger at all. It'll take a few days for all the solvent to flash off, but once it's gone, you're good to go.
Greg M
*Geek Extraordinaire
Images: 85
Postby working on it » Wed Aug 28, 2013 11:37 am
Greg M is right. I used lots of solvent-based paint (not stain) in the interior, and despite bringing back memories of model building in a closed room in the '60's (ah, the smell), the vapors were gone in days. However, stains and paints are different than enclosing yourself in a "treated" plywood box. I've read where some TnTTT builders considered using treated plywood for their floors, walls, and ceiling, to try to keep rot away. Maybe it would be possible, if an impermeable layer of paint or such separated the occupant from treated woods chemical vapors, but I wouldn't try it myself. Just an FYI for any reading this thread, just in case.
173193172890148599
working on it
Images: 457
Postby tscarbroughdc » Wed Aug 28, 2013 11:44 am
Thanks yall...
Im so excited...My windows and the door hinges came in today!!!!
I want to stain the inside some light colored looking wood finish whatever...I am building the WHOLE teardrop with marine grade plywood, so I dont know if that is "treated" or not!
tscarbroughdc
Postby working on it » Wed Aug 28, 2013 11:51 am
Pressure treated wood should be labeled as such, and is usually green tinted. Marine ply isn't treated, as far as I know, since there should be no ground contact (hopefully), nor insects aboard!
173193172890148599
working on it
Images: 457
Postby Bogo » Wed Aug 28, 2013 7:39 pm
TDs are usually so air tight you have to crack a window because of your CO2 output. Along with your CO2, any residual fumes will also drift off.
Bogo
Images: 39
