Looking for comments re BlueTop Optima
Postby hwitten » Wed Sep 18, 2013 3:54 pm
When it's time to replace my 55AH marine deep cycle I'm considering the D31M Optima. Seeing conflicting reports. Actually many reports say "stay away" but one has to take that with a grain of salt as usually only dissatisfied folks post/complain.
Anyone here using Optima? Perhaps D31M even?
My battery lives inside, hence plan to go AGM of some manufacturer.
Heinz
hwitten
Re: Looking for comments re BlueTop Optima
Postby Shadow Catcher » Wed Sep 18, 2013 5:29 pm
Get a true deep cycle battery and if you want an AGM go for a Lifeline. The Optima reputation comes from moving manufacture to Mexico and when you hear that many complaints there is likely good reason. Optima does not make a true deep cycle, the blue is a dual purpose.
Postby Dale M. » Wed Sep 18, 2013 5:32 pm
An alternative to OPTIMA....
http://www.odysseybattery.com/
Many sizes to choose from...
Dale
Dale M.
Images: 18
Postby planovet » Wed Sep 18, 2013 6:18 pm
I've had an Optima blue top for over 4 years now, no problems what so ever.
ImageMark (& Cindi)
planovet
The Cat Man
Postby Dale M. » Wed Sep 18, 2013 9:54 pm
planovet wrote:I've had an Optima blue top for over 4 years now, no problems what so ever.
IS it marked for "country of origin"...
Dale
Dale M.
Images: 18
Postby Shadow Catcher » Thu Sep 19, 2013 5:32 am
I spent most of my working career in the nondestructive testing end of quality control and I think many have figured out I am a bit obsessive about good/high quality products. Batteries are a perennial issue here and on other RV forums.
http://www.batteryfaq.org tells you who makes what battery, Optima is made by Johnson Controls who makes about a third of all batteries and their products run from low end up, how high is open to debate.
http://www.solar-electric.com/deep-cycl ... y-faq.html has a good over view of the science.
One of the problems is that what may well have lasted, years ago, has changed to who knows what.
Known good quality deep cycle (very few complaints)
Rolls http://www.rollsbattery.com
Concord/lifeline http://www.lifelinebatteries.com
Postby hwitten » Thu Sep 19, 2013 10:05 am
Thanks for all the additional info. Info is definitely helping in planning for next camping season. Winter trips will be with power available and/or just single overnights but next summer I'm hoping/planning for a return trip to Quebec and Atlantic Provinces, hopefully armed with a bit of French this time. School starts next month :)
hwitten
Postby Bogo » Thu Sep 19, 2013 11:35 am
Not only did Optima change manufacturing plants, but they also changed the makeup of the plates and separators to a much less costly design. The old Optimas could be abused. I'm now hearing that if you over discharge new ones, they can be permanently damaged the first time, and may need a very high amp charger to revive them.
Bogo
Images: 39
Postby d120 » Sat Sep 21, 2013 8:08 pm
thats pretty much what happened to my last red optima,not satisfied,got me a sears diehard platinum,Ive been much happier with it
d120
Postby working on it » Sat Sep 21, 2013 8:28 pm
Bogo wrote:Not only did Optima change manufacturing plants, but they also changed the makeup of the plates and separators to a much less costly design. The old Optimas could be abused. I'm now hearing that if you over discharge new ones, they can be permanently damaged the first time, and may need a very high amp charger to revive them.
I must've been lucky recharging my deeply discharged Yellowtop. It was down to 6.5vdc, and with guidance from this forum, brought it all the way back. Never went over 15amps to bring it back (I used my big charger at first, then changed to an AGM specific charger for successive steps in the process). I hadn't thought it possible. Now it stays at 12.8vdc. Haven't camped with it yet...time will tell.
173193172890148599
working on it
Images: 457
Postby jstrubberg » Mon Sep 23, 2013 8:00 am
Five years ago, an offroader not using an Optima was laughed at as a weekend warrior.
Now, offroaders shun them like the plague. The Optima has gone from top of the heap to the bottom.
The more stuff I take along, the more time I spend taking care of my stuff!
jstrubberg
Postby jonw » Mon Sep 23, 2013 6:03 pm
working on it wrote:I must've been lucky recharging my deeply discharged Yellowtop. It was down to 6.5vdc, and with guidance from this forum, brought it all the way back. Never went over 15amps to bring it back (I used my big charger at first, then changed to an AGM specific charger for successive steps in the process). I hadn't thought it possible. Now it stays at 12.8vdc. Haven't camped with it yet...time will tell.
I have a Yellowtop as well. It is designed to be more fully discharged and then recharged. One of the differences from the blue and red top models.
jonw
Titanium Donating Member
Images: 163
Postby emiller » Mon Sep 23, 2013 9:35 pm
Lifeline is the best you can get, They are used also for back on missile silos just in case you have one. 8) I personally always buy the Lifeline.
emiller
Images: 157
