Gladtobehere wrote:I remember that one. Toronto was ok. But further east was without power for many many days.
When you can,t even get gasoline, how many gallons should a person keep on hand? I figure for the short term the simplest thing to do is kepp your car filled. Never less than half a tank since the big blackout. For the long term I am not rich enough!
Wolffarmer wrote:Does a bug out trailer do much good in an ice storm? I for one would just set it out and not drive. While a small trailer would be easy to heat and all one would still want to try and keep the house from freezing up. Small trailer to keep a living space up to a comfortable temp while you keep house above freezing.
Randy
mikeschn wrote:Wolffarmer wrote:Does a bug out trailer do much good in an ice storm? I for one would just set it out and not drive. While a small trailer would be easy to heat and all one would still want to try and keep the house from freezing up. Small trailer to keep a living space up to a comfortable temp while you keep house above freezing.
Randy
That's exactly right Randy... "Small trailer to keep a living space up to a comfortable temp while you keep house above freezing!!!"
mikeschn wrote:Glenn,
That's the backup plan. Open one of the front windows, and instead of sliding in an air conditioner, I am going to slide in a forced air furnace, like the one below. The propane and the battery will sit on the front porch! I just have to build the perfect wooden enclosure for the window!
