eBay Turn/Stop LED Lights?
Postby jseyfert3 » Tue Jan 28, 2014 5:33 pm
Are the eBay LED lights usually okay? On my TD I'm building, I'd like to have stop/reverse and amber turn lights. Don't worry about how I'll control amber turn lights (it's very easy, actually), I'm just curious how random eBay signal lights work. Are they bright enough? Something like this perhaps?
jseyfert3
Re: eBay Turn/Stop LED Lights?
Postby tony.latham » Tue Jan 28, 2014 7:28 pm
Well, I think in the USA, your rear turn signals must be red. Maybe I'm wrong. Obviously, LED lights don't use much juice, but those wires look tiny.
TL
Postby wagondude » Tue Jan 28, 2014 7:43 pm
Rear turns can be amber in the US. More and more cars in the US are getting them now because they are required for export. To the OP I would suggest looking at the seller's feedback especially for similar items. They should work fine.
Bill
101137
wagondude
Images: 35
Postby eggsalad » Tue Jan 28, 2014 11:12 pm
tony.latham wrote:Well, I think in the USA, your rear turn signals must be red. Maybe I'm wrong. Obviously, LED lights don't use much juice, but those wires look tiny.
TL
That was true until 1968. As of 1968, any vehicle (powered or un-powered) may use amber rear turn indicators.
eggsalad
Postby tony.latham » Wed Jan 29, 2014 12:09 am
'68? You sure about that? That was the year I go my Tinker Toys. ;)
Postby jseyfert3 » Wed Jan 29, 2014 12:51 am
TL
Yup, what they said. I prefer amber turn signals myself, I think they tend to stand out more then a combined red stop/turn light. I think the reason no trailers have them is they aren't made for export, it adds cost, and would require a converter (which would actually be really cheap) or the introduction of an 8-pin trailer connector. I plan on using a 7-pin connector with the standard pinout and a DIY converter with a microcontroller and a couple power transistors to split the combined stop/turn signal into separate stop, left, and right signals.
Oh, and I think the wires look tiny cause I realized these lights are huge. A foot long and 5" high. :o
Does anyone know the legality of the front side amber marker lights? Specifically, can they be a dual-brightness marker light that flashes brighter along with your turn signal? Or do all trailer marker lights have to be solid?
jseyfert3
Postby GuitarPhotog » Wed Jan 29, 2014 1:23 am
Here's the NTSBs last word on the subject of trailer lights
http://www.nhtsa.gov/cars/rules/standar ... rpstr.html
<Chas>
GuitarPhotog
Images: 55
Postby jseyfert3 » Wed Jan 29, 2014 3:04 am
GuitarPhotog wrote:Here's the NTSBs last word on the subject of trailer lights
<Chas>
Thank you, that is very helpful. :thumbsup:
I found some more lights. I think these would look cool, 6" long oval, reverse LEDs in the outer ring, stop/tail LEDs in the inside. Then get an amber oval of the same size, mount both horizontally, with the amber below the stop/reverse. So many options to choose from. :thinking:
jseyfert3
Postby KCStudly » Wed Jan 29, 2014 8:51 am
I have used http://www.superbrightleds.com/ for all of the lighting needs on my build, inside and out; light switches, too. Very happy (so far) with the quality, price, service and ease of using their website.
No affiliation, just a pleased customer.
Postby jseyfert3 » Wed Jan 29, 2014 4:37 pm
KCStudly wrote:I have used http://www.superbrightleds.com/ for all of the lighting needs on my build, inside and out; light switches, too. Very happy (so far) with the quality, price, service and ease of using their website.
That site looks very nice. Most of the stuff is DOT approved too, and the eBay stuff is not. Thank you. :thumbsup:
jseyfert3
Postby wagondude » Wed Jan 29, 2014 10:20 pm
Might want to plan to have some corner reflectors for those times when you are parked dark. Some lights incorporate reflectors but if you choose lights without, it would be a good idea to add some.
Bill
101137
wagondude
Images: 35
Postby jseyfert3 » Thu Jan 30, 2014 12:49 am
wagondude wrote:Might want to plan to have some corner reflectors for those times when you are parked dark. Some lights incorporate reflectors but if you choose lights without, it would be a good idea to add some.
Good point. I was planning front and rear side marker lights with combined reflectors, and rear lights and reflectors. Your post make me think about front reflectors, I probably want one on each corner in the front too. If I was tucked into a spot and someone somehow missed me and tried backing in, the front reflectors would hopefully get their attention.
jseyfert3
Postby jseyfert3 » Tue Apr 01, 2014 12:05 pm
I just spent $187.20 on your suggestion, so I better be happy! :R
I ordered the brightest round red taillights at 234 lumens! With these, I ordered amber versions of the same for turn signals, an oval high brightness stop/tail light which will be used only for a high mount stop light (not wired for taillight), two amber/two red marker lights with reflectors for the sides, two red reflectors for the rear, various plugs required for the lights, a license plate light, and four 3 W dome lights. At 480 lumens/each, I plan to have one inside the TD, and three on the inside of the hatch for a very well lit galley area if I'm cooking at night.
Now it's time to start working on my signal adapter. I'm going to use a standard US wiring hookup for the trailer lights, with a microcontroller and some transistors or MOSFETs to "split" the combined stop/turn signal into separate stop/turn signals.
jseyfert3
Postby jseyfert3 » Fri Apr 04, 2014 12:22 am
Got my haul of lighting today, can see the pic of said haul on my build thread post.
jseyfert3
Postby lthomas987 » Fri Apr 04, 2014 11:03 am
I know they flash on both my boat and utility trailers. I don't know if they are supposed to flash, but both were wired according to the instructions. I've also seen amber flashing turn indicators on the side of semi-tractor trailers.
Laura
Laura
Bike-Drop a Micro-Foamy Build Journal http://www.tnttt.com/viewtopic.php?f=50&t=59274
My first Superlegarra-ish Foamy build http://www.tnttt.com/viewtopic.php?f=55&t=59049
lthomas987
Images: 204
