eBay.
D1LC Linky
The shipping from England isn't as bad as you think it would be so don't limit your search to the US.
rdemler wrote:Aside from the noise,does anyone have any opinions on a generator for running heaters and everything else that might be needed.I'm kinda looking at a honda 2000.I've heard they were super quiet and dependable.Would kinda solve most problems I'm reading about 12v and heaters.Most of my camping would be done in Montana and the U.P. of Michigan and away from campgrounds.Any thoughts on them??
rdemler wrote:I'm waiting on my 7x14 deep vee nose to get here so I'm thinking of options.I'm looking for ideas on the best way to go for heating.It will be insulated and vented.I was thinking a portable heater of some kind that runs on gas with no fan needed.I'm also wondering how much ventilation is needed for a trailer this size with a gas heater.Any ideas will be greatly appreciated.Thank you!!
McDave wrote:I'm in Montana and when I am boondocking I have a Wave 3 Catalytic Safety Heater that does a super job in my 6 x 12, and requires no power. They produce no harmful amounts of carbon monoxide. The recommended venting is to raise the roof vent 1/4 to 1/2 inch (14 x 14) and to open a window 1/4 to 1/2 inch. Catalytics don't have a flame, they work by chemical reaction when gas and air are brought together in the presence of platinum, but they do use oxygen so you need to let some in. These are radiant heaters that heat objects much like the suns rays heat objects. It is a very effective way to heat and quiet and comfy. 99.98% efficient as opposed to flame heaters that are about 55-60% efficient.
Here is a PDF with all the information.
http://www.dyersonline.com/downloadfile ... le_id/575/
McDave
PrecisionLook612 wrote:McDave wrote:I'm in Montana and when I am boondocking I have a Wave 3 Catalytic Safety Heater that does a super job in my 6 x 12, and requires no power. They produce no harmful amounts of carbon monoxide. The recommended venting is to raise the roof vent 1/4 to 1/2 inch (14 x 14) and to open a window 1/4 to 1/2 inch. Catalytics don't have a flame, they work by chemical reaction when gas and air are brought together in the presence of platinum, but they do use oxygen so you need to let some in. These are radiant heaters that heat objects much like the suns rays heat objects. It is a very effective way to heat and quiet and comfy. 99.98% efficient as opposed to flame heaters that are about 55-60% efficient.
McDave
Do you notice moisture buildup inside when you run it or does the venting take care of it? I keep reading/watching conflicting stories on catalytic vs vented.
troubleScottie wrote:Burning propane will generate carbon dioxide and water. Catalytic or not, the chemical process is the same. Mixing propane and oxygen can only generate this outcome. This in not nuclear fusion or fission.
