Undercoating
Undercoating
Postby camper4life » Sun Mar 16, 2014 10:46 pm
How many coats of asphalt coating do most of y'all put on the underside of trailer?
camper4life
Images: 39
Re: Undercoating
Postby Martiangod » Sun Mar 16, 2014 10:59 pm
None on mine, used coroplast
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Re: Undercoating
Postby grant whipp » Mon Mar 17, 2014 12:20 am
ONE ... 1 ... good thick coating ... let set for at least a couple of days.
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Re: Undercoating
Postby 48Rob » Mon Mar 17, 2014 5:57 am
I used two.
The idea was to provide a cushion to protect the oil based paint I used to seal and waterproof the wood from rocks, spray, etc.
Still in good shape 8 years later.
Rob
48Rob
Re: Undercoating
Postby TPMcGinty » Mon Mar 17, 2014 6:21 am
I put two coats of an asphalt based fence post paint I bought at Tractor Supply. Has worked good so far.
http://www.tractorsupply.com/en/store/gardner-gibson-fence-post-black-beauty-asphalt-fence-paint-1-gal
Tim
TPMcGinty
Images: 146
Re: Undercoating
Postby les45 » Mon Mar 17, 2014 7:08 am
I used two coats of Henrys over two coats of Zinsser oil based primer. The main reason I used the primer was to make sure the Henrys didn't cause my plywood to delaminate.
les45
Images: 605
Re: Undercoating
Postby bobhenry » Mon Mar 17, 2014 7:42 am
TPMcGinty wrote:I put two coats of an asphalt based fence post paint I bought at Tractor Supply. Has worked good so far.
ME TO ! :D
Re: Undercoating
Postby absolutsnwbrdr » Mon Mar 17, 2014 8:48 am
Two or three coats of Black Beauty Fence Post Paint for me. The stuff dries in a few hours, instead of a few days like Henry's. And its specifically made to stand up to direct contact with the ground and to resist moisture and bugs. Can't beat it for the ease of use, or the price. Then I use an asphalt based caulk in joints. The asphalt caulk and undercoating play very well together.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Re: Undercoating
Postby DMcCam » Mon Mar 17, 2014 11:40 pm
I used spray on bed liner (the professional grade two part stuff). So far so good with 1 year and about 1,000 miles of camping.
Cheers,
Dave
DMcCam
Re: Undercoating
Postby eamarquardt » Tue Mar 18, 2014 10:30 am
I needed to provide a waterproof membrane for my new shower and discovered this stuff: http://www.homedepot.com/p/Custom-Build ... 169081-_-N
It goes on easily with a roller or brush, cleans up with soap and water, dries quickly, is 100% waterproof, flexible, tough, and dries to a bright red color (the only downside but as it's under the trailer who really cares).
IMHO it's an excellent material to waterproof and rockguard the underside of a trailer.
My two scents.
Cheers,
Gus
eamarquardt
Images: 150
Re: Undercoating
Postby Woodpecker » Tue Mar 18, 2014 12:27 pm
I used the standard asphalt coating. 2 good coats with a day to dry in-between.
Not from experience mind you, just from the advice I got here. :thumbsup:
Woodpecker
Images: 186
Re: Undercoating
Postby camper4life » Tue Mar 18, 2014 8:40 pm
Thanks for all of the ideas and suggestions. I just finished putting on another coat on. Hopefully the floor will be ready for walls this weekend.
camper4life
Images: 39
Users browsing this forum: Bing [Bot] and 6 guests
