I'm amazed I didn't lose my trailer - I should have.
Re: I'm amazed I didn't lose my trailer - I should have.
Postby eggsalad » Sat Apr 12, 2014 7:13 pm
If this doesn't work, I'm just an idiot! :)
eggsalad
Postby Redneck Teepee » Sat Apr 12, 2014 9:54 pm
eggsalad wrote:If this doesn't work, I'm just an idiot! :)
It works for me!.... and I'm sure it will for you too! A good walk around and double check like you did, your hitch would not have caught your eye or jumped out and bit you...but it will now before you even get hitched up. I'm all for anything that's simple and prevents accidents. :thumbsup: :thumbsup: :thumbsup:
Redneck Teepee
Images: 21
Postby AlgoDan » Sun Apr 13, 2014 6:00 am
Dang are you ever lucky, glad you made it back.
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby wincrasher » Tue Apr 15, 2014 10:23 am
You were very lucky as others have pointed out.
I've had a couple occasions where when I got to my destination, I found that I forgot the security pin on the coupler, and it had popped up. So the tongue weight was all that was holding it to the ball. Now I make the habit of always returning the pin to the holes, whether up or down, and not just setting the pin on the tongue, the ground or whatever.
I am curious though, did you not have a lot of "noise" during your trip. Like clunking, screeching, etc. I'd suspect if your chains were all that were holding it in, you'd have had a lot of bumping and banging.
2015 Little Guy T@G Max
Follow my blog: http://www.wincrasher.blogspot.com
wincrasher
Images: 88
