by working on it » Thu May 15, 2014 10:03 pm
Nice build. Like your cabinets. A warning, though: if your trip follows the route shown (in your link), in early to mid July, over the southern parts of Louisiana and Texas, be ready for upper 90's temperature / incredible humidity. If you're not used to the climate (and even if you are), be ready for sweltering nights. I don't see any A/C in your photos, nor a high flow fan (the only alternative to A/C, IMHO). And cross-flow ventilation helps, too. Consider adding screened windows on both sides. Anyway you go, have a nice trip!
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
