1st time build, Suprise for the wife (9-10,wall panel added)
Re: 1st time build, A surprise for the Wife :)
Postby S. Heisley » Fri Aug 01, 2014 9:53 pm
BuildingForFun wrote:
S. Heisley wrote:Oh, also, for aluminum to wood, you might try 3M 4200 or 3M 5200 glue. These are used on marine applications. I think Aggie79 used 4200 and it might be more to your liking. Be careful of 5200 as, once dry, it will never come loose. It'll tear up your wood if you try. :oops:
Thanks, I am assuming this will be good glue to use on Wood to Wood? like when jointing the walls?
The 3M 4200 and 5200 is pricey; plus, for bare wood it's really, really hard to go wrong with Titebond III. For epoxied or varnished wood, PL2000 construction glue works fine. Neither Titebond nor PL2000 work well with aluminum. I used PL2000 when joining my walls to the floor and to each other, along with a few well placed bolts(floor) and screws(walls).
For bare wood, it's hard to beat Titebond III (provided you follow instructions); plus, once dry, it is a waterproof glue. Yet, while it is still wet, you can wash it off with water or wipe it off with a damp cloth. How strong is it? Here is a picture of some pieces that I tried to carefully pry apart:
Postby BuildingForFun » Wed Aug 06, 2014 7:32 am
Slowly making some progress. Only made it out to the garage for a few hours on Saturday, was able to use biscuit jointer to joint together the 4 pieces of plywood, Glue them, then added some wall studs.
Last night I added a 2nd layer of plywood underneath the first, this will be for the other wall. Tonite I hope to finish routing the first wall, and by routing just a little deeper it will also rout out the design on the 2nd layer for the 2nd wall. Then should finally be able to stand the wall up and get a profile photo......That will feel like a mile stone for me. :)
Also I changed the front lower profile a little bit to make it not quite so rounded at the bottom.
Heres a few photos of Saturdays work
Gluing the wall studs.
New Profile routed on lower half of front.
Last edited by BuildingForFun on Wed Aug 06, 2014 7:35 am, edited 1 time in total.
BuildingForFun
Postby BuildingForFun » Wed Aug 06, 2014 7:34 am
Jointed, Glued, and wall studs screwed together.
BuildingForFun
Postby KCStudly » Wed Aug 06, 2014 9:55 am
Ooooh, Viper. :thumbsup:
Postby Sheddie » Wed Aug 06, 2014 4:25 pm
Yes! Also taken note of the Viper. Just keep putting those sneaky car photos in the background.
Sheddie
Images: 1129
Postby BuildingForFun » Thu Aug 07, 2014 6:55 am
Lol, my drive way is just to small....they jump in the photos all by them selves....... Consider yourself forwarned, photos of lasts nites work include a Vette in the back ground.
BuildingForFun
Re: 1st time build, Profile photos, A surprise for the Wife
Postby BuildingForFun » Thu Aug 07, 2014 8:12 am
So, Last night I feel like I made it to my first milestone. I mocked up one wall for a profile photo...... :) :) :) I was so please that I didnt want to take it back down. I am very pleased with the overall shape, Just need to make one last minor change. The other thing I decided was to switch from a straight axle ( which is what we keep in stock), to a drop axle ( which will be a special order). I will make this change later. The bottom of the frame is about 17 to 18 inches off the ground right now, with a drop axle I hope to lower it to about 10 to 12 inches.
I took quite a few photos of the wall stood up (just really excited) PLEASE LET ME KNOW WHAT YOU GUYS THINK. Thanks.
FINALLY!!!!!!!!!!!!!
Last edited by BuildingForFun on Thu Aug 07, 2014 3:31 pm, edited 1 time in total.
BuildingForFun
Postby BuildingForFun » Thu Aug 07, 2014 8:17 am
More Photos
BuildingForFun
Postby BuildingForFun » Thu Aug 07, 2014 8:18 am
Last ones. :?
Back Side
BuildingForFun
Re: 1st time build, Profile photos upload, surprise for the
Postby Sheddie » Thu Aug 07, 2014 4:26 pm
Wow! That's a monster! Very nice shape. Teardrop that is. :beautiful: I hope the wife was out, she would have been hard pressed not to see it parked in the drive.
:snappy: Keeping a note on driveway occupants. Nova, Cobra, Corvette. They would all look good in my shed.
Sheddie.
Sheddie
Images: 1129
Postby S. Heisley » Thu Aug 07, 2014 7:25 pm
Sheddie wrote:Wow! That's a monster! Very nice shape. Teardrop that is. :beautiful: I hope the wife was out, she would have been hard pressed not to see it parked in the drive.
Sheddie.
Regardless of whether the wife saw it or not, I think she is going to be amazed!
Postby lee senn » Fri Aug 08, 2014 6:54 pm
Looking great! I think you really nailed it on the shape. I am looking forward to following the rest of your build. Lee
lee senn
Postby BuildingForFun » Mon Aug 11, 2014 9:22 am
Sheddie.
Way to make me feel terrible about its size :oops: .....lol jkn. I guess I should update a few things.....since I started the build, a few things have changed.....I have acquired a dodge 3500, so weight and size will no longer be an issue. And I decided that, (While the smaller they are, the cuter they are. I would rather go for a lil bigger with more room.) Hopefully the profile will keep it looking cute.
And I had her draw the curtains tight.....so she would not see anything.
BuildingForFun
Postby BuildingForFun » Mon Aug 11, 2014 9:25 am
Also thanks everyone for the encouragement on the profile shape. :)
BuildingForFun
Postby Sheddie » Tue Aug 12, 2014 4:02 am
Sheddie.
No criticism intended. You are making a fab job. Just think, if they were all the same size and shape, most of the discussion on this site wouldn't happen.
I can not imagine my wife not taking a sneaky look through the curtains! :angel:
Sheddie
Images: 1129
Users browsing this forum: Bing [Bot] and 11 guests
