rowerwet wrote:Having a tear is great, I still do at least one trip a year canoe camping, unless I figure out an easy way to put the tear on floats, I will still be tent camping.
rowerwet wrote:I found adding water to the gg joints caused heavy foaming and swelling, just running a bead of gg and leaving it works fine. Of course I'm in a damp basement, it may depend on your local humidity levels
I would save some money though and do the fabric coating bonding with titebond II, save gg for foam to wood or foam to foam joints..
Pmullen503 wrote:While the glue was drying I spent about a half hour steaming the stamped in writing out. The writing was pressed in almost 1/16" and would definitely have shown through the covering. I used a piece of wet cloth and a hot iron. Lay the wet cloth over the writing and press with a hot iron. As long as steam is being formed you're OK. As soon as the cloth starts to dry out the temperature can go up rapidly and melt the foam. The foam will expand back to it's original size and the depressions will be gone (works for dents too.)
ghcoe wrote:Good idea.I will have to remember that. I filled mine in with spackle. Most where not very deep like yours though luckily. Could be because I had the trailer out in the sun some before painting.
