GPW wrote:PM , I believe we’ve all been trying to get the absolute Best bond between Foam and canvas (fabric) and the TB2 has proven to work very well so far ... If you’d like to independently “test” the poly/foam/fabric join , we’d really appreciate hearing about it !!!
rowerwet wrote:I have a few ideas but have done only Wiley windows in plywood so have no actual experience.
Make the door of two layers of 1" foam glued together. Cut the inner piece to fit the whole window assembly, and the window hole in the outer face to be the frame the window and screen seal against.
A thinner outer layer of 1/2" foam might be better still, I'm planning a foamie this year, the doors will be framed in wood, and probably be skinned with 1/4" ply.
You could also cut through the door and add a frame of wood or foam to the outside of the door to seal the window, this way the support angles for the inside would be less obtrusive. I saw a barn with windows set into a 2x4 wall that way. There were no brackets intruding past the inside wall, just the top of the window when opened. The supports were simple diagonal strips nailed to the inner frame.
