Stepping into the TearDrop void
Re: Stepping into the TearDrop void
Postby dales133 » Tue May 05, 2015 1:06 am
Good stuff mate that ply looks good
dales133
Postby trailtroll » Tue May 05, 2015 2:27 am
We are hoping that when the varnish goes on it will high-light the bamboo segments.
:vroom:
I woke up this morning and all of my stuff had been replaced with exact replica's
trailtroll
Postby trailtroll » Tue May 05, 2015 2:28 am
I will use a half/split length of Bamboo to cover the seam between the ply sheets
:vroom:
trailtroll
Postby dales133 » Tue May 05, 2015 2:34 am
Varnish will definatly lift the grain.mine looked miles better after a few coats
dales133
Postby trailtroll » Mon May 11, 2015 7:55 pm
Frank, what size are your gas struts, and how do you work out the correct placement for them? And have you come across mechanical versions?
:vroom:
trailtroll
Postby trailtroll » Tue May 12, 2015 2:27 am
Thanks for the visit Frank, it was inspirational, there are some good ideas in your head.
:vroom:
trailtroll
Postby Sheddie » Tue May 12, 2015 5:09 am
Thanks Wayne, it was good to finally make the time to call in and have the opportunity to see another TD under construction. You are making a great job :thumbsup:
Thanks for the cuppa, and the peanut brownies really are just like Mum used to make. :)
Sheddie
Images: 1129
Postby trailtroll » Thu May 14, 2015 4:49 pm
I have managed to find two boot stays, $85 pair, these will be used on the galley hatch.
:vroom:
trailtroll
Postby Sheddie » Fri May 15, 2015 2:30 am
trailtroll wrote:I have managed to find two boot stays, $85 pair, these will be used on the galley hatch.
Is that another set of gas ones, or did you find some of the old fashioned locking slide ones we were talking about?
Sheddie
Images: 1129
Postby trailtroll » Fri May 15, 2015 4:31 am
The really old fashion ones, they are called boot stays. I found one at the RV place at Otaika, and they managed to order me another, they are just what I wanted.
Off to Para-Rubber tomorrow to see the little racks that Dale got for your TD, plus some rubber seals.
:vroom:
trailtroll
Postby trailtroll » Sun May 17, 2015 10:34 pm
Nearly there, the galley is well on the way, just starting the wiring, then the cladding.
:vroom:
Struts in place.
Galley nearly finished
trailtroll
Postby Sheddie » Mon May 18, 2015 5:34 am
Sheddie
Images: 1129
Postby trailtroll » Mon Jun 01, 2015 10:30 pm
Frank, we are looking for the same type of door stop that you have on your teardrop, can you let us know where you sourced them, cheers
:vroom:
trailtroll
Postby Sheddie » Tue Jun 02, 2015 4:06 am
Hi Wayne
We got ours from Recreational Concepts South End Ave. They come with a plastic bush with a screw in it to adjust the tension. We took that out as they hold well enough without.
Sheddie
Images: 1129
Postby dales133 » Tue Jun 02, 2015 5:00 am
Got a pic of the door stop Frank? I'm wondering what to use on mine.was considering magnetic but havnt found anything low profile enough.
Nice work wayne
dales133
