I am going to finish the door frame using bondo and paint, so the door opening will not require a molding. I only want to use the molding for the doors themselves.
![Image](http://i39.photobucket.com/albums/e157/SMBandit/IMG_2687-1.jpg)
Thanks!
![Thumbs Up :thumbsup:](./images/smilies/econ_thumbsup.gif)
asianflava wrote:Whew, that is pretty tight. What you may have to do is anneal a piece and bend it, then anneal it again and bend it some more. I played with different thicknesses and found 1/8 to work out OK, the thinner pieces would buckle.
But like I said, that radius looks pretty tight so I don't know if it would work.
Bandit wrote:I do plan to notch the inside radius.
What do they use this for in a carpet store?
Thanks!
Bandit wrote:Rickxr2,
Where did you get the drip rail?
I could add some radius to my doors, but it would require adding a filler and a lot of finish smoothing work to make it un-noticeable.
