Laminated structural insulated panels
Postby Bad4Fun » Wed May 31, 2006 3:56 pm
Where can I get this type of material for wall and bulkhead
construction..Need to save as much weight as possible.
Could have aluminum outer skin..Insulated core.
or honeycomb construction...preferred insulated.
Maximum 2" thickness..would be great if I could get 5' x 9'
panels or 5' x 5' something along those lines.
Any Ideas....????
Bad4Fun
Postby Miriam C. » Wed May 31, 2006 7:56 pm
Bad4Fun
Try this thread
http://www.tnttt.com/viewtopic.php?t=7543
If you have a specific thing you are looking for the search button above may be of use.
Hope it helps
Miriam
Postby GPW » Thu Jun 01, 2006 7:18 am
OH! NOOOOOoooooooooo......Not Again !!!!!!! :o
Postby madjack » Thu Jun 01, 2006 8:48 am
GPW wrote:OH! NOOOOOoooooooooo......Not Again !!!!!!! :o
G, you will find that the same subjects/ideas come up onna regular basis...this is one of them but unless you can make 'em yourself there is no way to get an appropriate made/sized panel that is affordable commercially....
madjack 8)
Sounds like this is old news..
Postby Bad4Fun » Thu Jun 01, 2006 12:12 pm
Sorry guys, I know better than to through out a topic
without searching first for past threads of the same
nature..
Anyway thanks to those who added two cents...And
madjack, I think you are right on, to get exactly
what I want I will have to fabricate it myself.
David.....aka Bad4Fun
Bad4Fun
Postby madjack » Thu Jun 01, 2006 4:43 pm
b4f...don't worry about throwing out an idea that may have been discussed...somebody who wasn't here then may have new info/ideas to toss into the rink...the idea is a good one and commercial RV manufacturers use the technique almost exclusively...the link Auntie M gave you is a good one if you should wanna tackle the problem yourself...lotssa good info contained in it..........
madjack 8)
Postby Bad4Fun » Fri Jun 02, 2006 9:23 am
madjack wrote:b4f...don't worry about throwing out an idea that may have been discussed...somebody who wasn't here then may have new info/ideas to toss into the rink...the idea is a good one)
Thanks madjack......b4f
Bad4Fun
