Now that the roof on the house is done, and all the tools resorted and restored, we wanted to get the roof on the vardo sorted. We went with a canvas/TBII method -- first we skinned the whole thing with plywood, running it in 2' wide sections down the curved sides, covering the seams with 2" wide strips of plywood glued and nailed. Caulked the whole thing, then got some 4 x 8' tarps from Harbor Freight to use for our canvas top. I liked how heavy the canvas was, and the 4' wide strips matched our spacing.
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/967798_orig.jpg)
Gluing it down went pretty smoothly, we have little bits here and there that we had to piece, but since it's all going to be overhead, mostly out of view, we didn't fret too much about the little patches here and there. We did the two curved sides, then ran a piece over the center.
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/5151825_orig.jpg)
Before we ran the center piece, we first did the overhang of the skylight and the curve where the center panel meets the sides. This is where most of the patchwork went, but again, from the ground it's not visible, so as long as the patches covered any seams, we were A-OK with it.
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/9516871_orig.jpg)
In the pic above, you can see the wire stub we left - we ran wire up before we finished off the roof, we are going to add solar panels on the top of the skylight, so again, no worries about seams since it's not visible and it'll be covered up with solar panels. We also added the curved end boards, pieced from 1 x 6s, and ran the canvas up on those, as well as on top of the side boards. Before we attached the plywood, we ran some freeze/thaw for the bottom 8" as a way to help keep moisture out.
After we got the canvas all adhered, I painted a coat of thinned TBII over the whole surface, and inspected the adhesion. The only place we struggled with was the concave curve at either end of the skylight, as the canvas shrank with moisture, it wanted to pull up there, so we weighted that down with sandbags overnight while it was wet, and it was all glued down nicely this morning. I coated the whole roof with acrylic gesso, which is what us artists use as a primer for painting on canvas - I had a gallon of it, and it's acrylic and nice and thick, and meant to provide a stable barrier for oil paint and acrylic, so I figured it would be a good start. I also gave it one coat of exterior latex that I had around the house, and I am hoping to give it two more coats tomorrow.
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/7981952_orig.jpg)
originally, my idea for the final paint job was an overall pattern, but I really like the ridges, so I have a new plan that will incorporate those. With any luck, I'll get the roof painted this week, unless it looks like it might rain. We also fitted the stained glass into place in the sides, using the same cool hinges - those were so great, I so appreciate the suggestion! I ordered some really cool latches but am making adjustments on how to install them, so the windows are still being held in place by a temporary toggle.
Since we couldn't work on the vardo last week while we were getting our house roof replaced, I brought in the doors and did the decorative paint on them, working at the kitchen table. Last I posted, you could see how ridiculously red those doors were -- but I knew they'd get toned down. Here are the painted doors, I laid them down together on the driveway to see how they look together --
I am going to do the same type of flower painting along the black upper boards on the vardo, and I have a lot of stencils I want to incorporate as well. The birds are a favorite subject for me, so I had my husband pick two (he choose blue jay and cardinal), and I chose two (crow and seagull). The visual theme for the paint on the outside will be nature, with lots of flowers, birds, butterflies, etc --
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/7678917_orig.jpg)
The top still has a space open for a mosaic:
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/1750710_orig.jpg)
I have a cheapie brass pocket compass coming via ebay, and I'll find other fun bits and pieces to put up there, and then I'll use black grout to fill in the spaces. After I got the decorative painting done, I gave it a coat of spray acrylic to protect the paint, then washed it down with a thinned coat of black paint to give it an antique look. That toned down the red considerably, and I'm happy with the doors. The strap hinges I have will cover some of the flower painting, but that is OK.
I also did a little testing out of some of my stencils - I added some clouds (my husband's idea, it was a good suggestion) to the sun/moon, and added the borders as well:
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/3779057_orig.jpg)
I still have to paint the soffit and the end board here. I also added some gold highlights and tried out a couple of stencils on the window next to the door:
![Image](http://coolclevername.weebly.com/uploads/5/9/2/6/5926741/2495728_orig.jpg)
So ...that's where we're at this week. My goal this week is to get the roof painted, get those windows made for the skylight, then install the door and get this place weather-tight. We've also picked up a couple of furniture pieces free on Craigslist that we'll be re-purposing for the interior, so that's a fun project in our future, after we figure out the layout and the electrical --
