GPW wrote:“ It’s the Tooth... the Tooth !!! “
KCStudly wrote:Why thank you funluvin, thank you very much, and welcome to the build.
KCStudly wrote:Where did I leave off? Oh yeah, prep for paint and final finishing. Following the West System method I purchased a can of 410 Microlight filler thinking that this, combined with epoxy, would be good for filling the weave. Now I'm wondering if high build primer would be more efficient and cost effective. <Snip>
KCStudly wrote:I like the results that Becky got using Interlux boat paint on the Sagwagon. IIRC she used epoxy (not poly or vinylester resin) and glass over wood. Interlux website says it is good on FRP and GRP but I did not see where it was specific to epoxy resin; I assume it is compatible. They offer both two part and single part products; single part would be nice because it adds an element of fool proofing.
KCStudly wrote:Thanks for the details and advice. There are so many choices to make. Which epoxy primer did you use?
Users browsing this forum: Google [Bot], jgmahoney and 11 guests
