Side walls;
- 2 5x10 plywood for outer wall
- Use 1x2 for framing (use 1x3 for joining wall to floor)
- Use 3/4 inch hard foam insulation (? Is this right or should it be 1 inch)
S. Heisley wrote:Side walls;
Yes, that is correct, if you are purchasing your 1x2" wood and not cutting it yourself. This is because manufactured 1" wood is really 3/4". (They think they are tricking us; but, we know....)
Also, 1x2 boards are plenty strong enough for the roof. You don't need 2x2 boards. The cabin gets its strength from the entire unit, not just a couple boards. Also, the bunk beds, attached from side to side will help stabilize the unit and take the place of the galley cabinets, which normally do that. I don't know what you have for a tow vehicle; but, assuming it isn't a truck, you'll want to keep the weight down. Since you don't have brakes on your trailer, you'll need to keep the weight under 1500 pounds anyway.
A Rimple is a good choice for your first build. Keep going. We're watching!
KCStudly wrote:It is better to run the roof spars standing on edge. Not only are they stronger that way, but by separating the inner and outer skins more, the whole roof structure becomes stronger; and there is more room for insulation.
Do you mean to not skin the underside of the floor, just deck with insulation underneath? That has been done successfully in the past. It would be a good idea to fully seal the wood first. Epoxy, paint, "the mix", tar and other methods have been used.
Bob Henry (and others) like to put the extruded insulation on top of the floor and then just put the mattress over it.
I'm in the camp that likes the idea of a torsion box or SIP style of floor construction; thin skins top and bottom with a foam core.
KCStudly wrote:So the difference between a foam mattress and foam carpet backing, and hard foam insulation is that the hard foam will not tend to absorb and hold moisture; at least not nearly as much as the spongy foams.
Several people have reported that w/o hard insulation under a spongy foam mattress humidity (moisture from perspiration, breath, and/or coming in from rainy weather with damp clothing... don't even try to pull the old, "but I will only be camping in good weather" ploy... everybody gets rained on sooner or later), especially in cold weather camping (cold weather = anywhere below the dew point... doesn't necessarily have to be "too cold to camp") can collect in and under the mattress, potentially becoming the start of a mold problem. Others, especially people who live in very dry climates like Arizona, etc., never run into this problem.
My thought is that: 1) I live in region with the potential for very humid weather in the summer; 2) I would like to be able to camp pretty much anywhere in the country, thru at least 3 seasons, and at times at high elevation where overnight temps can drop dramatically, even in the middle of summer; and 3) my wife is very intolerant of any thing resembling cold, so I went with sandwich construction and 1-1/2 inches of foam. Some may say overkill, but if there is morning frost or it snows a little at Poet Creek, even in late August, I would not be very much surprised.
S. Heisley wrote:KC is giving you good advice. Actually, you will get less moisture build-up if you add Styrofoam underneath your floor. What I did for mine was fit Styrofoam between the boards, using a light spray glue to attach. Even though I had epoxied the under side of my floor, after I finished securing the hard foam, I sprayed everything with undercarriage spray, which you can get at an auto parts store. It is said that you can secure the foam with large washers, screwed into your boards; however, I secured mine with metal plumbers tape, too. (I also used hardware cloth; but have since become convinced that the hardware cloth was over-kill and unnecessary.) You can wait to see how you fare and do all this later; but, it will be harder to do when you are laying on your back, looking up.
The evenings do get cold in California, above Sacramento; and, especially if you plan to go into the mountains or over to the coast. Parts of the coast are often in the upper 30's in the mornings and sometimes don't get above the cold, foggy 60's in the daytime. It just depends on where you go. In the Sierras, especially near Lassen National Park, it can be in the upper 80's in the day time and still get down into the mid-30's at night. This is because there are underground ice caves (lava tunnels) that never thaw and these act like a refrigerator as soon as the sun goes down. As long as you have Styrofoam insulation in your floor, walls, and ceiling, you will do very well, staying at least 10 degrees (or more) above the exterior night time temperatures. The insulation will also help keep your trailer cooler during the hot summer days, keeping your trailer the temperature of a shaded area, even when left closed up in full sun for hours. It quiets down noise, too.
Yes, set your ceiling spars uP for added strength. This also allows you to put two layers of 3/4" Styrofoam insulation in your ceiling area, where you need it the most. Styrofoam is inexpensive, easy to work with and adds almost no weight; so, why not?!
