Fantastic VENT, upgrade to fan?
Postby SPLAT » Tue Feb 02, 2016 9:49 pm
I unfortunately have a vent and not a fan.
I would like the fan version but don't want to have to buy another complete fan.
I have looked hard to find the motor and fan assembly but can only find upgrade kits for units that already come with a fan.
I have found articles where people break their vent lid, buy the static vent and swap the parts...
Any help to get me a fan would be greatly appreciated :thumbsup:
Joe~
SPLAT
Images: 23
Re: Fantastic VENT, upgrade to fan?
Postby noseoil » Tue Feb 02, 2016 9:58 pm
Some people make a setup with computer fans. They are inexpensive, use very little current & will fit in a frame. Take a look at some of the ideas using computer fans with a search. viewtopic.php?f=30&t=64724
137905
noseoil
Images: 670
Postby Vedette » Tue Feb 02, 2016 10:58 pm
noseoil wrote:Some people make a setup with computer fans. They are inexpensive, use very little current & will fit in a frame. Take a look at some of the ideas using computer fans with a search. viewtopic.php?f=30&t=64724
We have two computer fans for our are circulation system in Miss Piggy as we did not want to cut a hole in the roof?? ;)
They work Great! :thumbsup: And run quietly all night as we sleep. :thumbsup: No condensation! :thumbsup:
Have two more to install in our new build Kermit! :applause:
If it works....Why re invent the wheel?? :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby SPLAT » Wed Feb 03, 2016 1:40 pm
I was hoping for the actual fan insert...
Joe~
SPLAT
Images: 23
Postby jss06 » Wed Feb 03, 2016 6:27 pm
I have a fan that I destroyed the lid on. I left it up when I backed it into the garage. The lift mechanism is bent out of shape but everything else is good. Where are you located. I am in the Dallas/ Fort Worth Texas area.
jss06
Palladium Donating Member
Postby Shadow Catcher » Wed Feb 03, 2016 9:44 pm
The first picture is our current teardrop the other two are its predecessor. Same fans, but it the second iteration I used a DPDT switch so that one or both fans can be used.
796565468254681
Very seldom do we have the fans on high speed .
Postby SPLAT » Thu Feb 04, 2016 12:10 am
I am on the southern oregon coast, Bandon Oregon , are you interested in selling it? :thinking:
Joe~
SPLAT
Images: 23
Postby SPLAT » Sun Feb 28, 2016 9:42 pm
Installed, works great... Took a little modification because the flanges were different :thumbsup:
fan upgrade.jpg (11.45 KiB) Viewed 857 times
Joe~
SPLAT
Images: 23
Postby jss06 » Mon Feb 29, 2016 7:53 pm
SPLAT wrote:Installed, works great... Took a little modification because the flanges were different
Awsome. Glad it worked out for you.
jss06
Postby Tomterrific » Tue Mar 01, 2016 10:42 am
Rather than a fan, I wish I had installed another vent. I could even see having three vents, two up front over our heads and one in the rear.
T
Tomterrific
