Thanks Julie,
This thread was a classic and deserved to be revived, not like the many that deserve to be labeled "DO NOT RESUSCITATE"
Steve_Cox wrote::thumbsup: Julie,
I got my A/C ideas from Woody and used a 6" diameter, 600 cfm, bathroom exhaust fan from H/D. I also put in a switch for the exhaust fan and tied the outlet for the air conditioner to it. That way the A/C can't run unless the fan is on.
Tear Fan wrote:Anyone have any ideas on installing a Petcool in a Silver Shadow? I have a 33" by 18-1/4" space in the galley where I am thinking of putting this unit. It has two duct hoses that I will channel through the wall between the galley and the cabin, as high as I can get them so as not to block them with mattress and blankets (and feet!) Can I run the unit with the galley door closed? If I put a vent in the floor of the galley for heat exhaust, won't that allow water up from the road when in transit? Anyone? Anyone?
madjack wrote:Steve, I have been meaning to ask...what didja do about about condensate drainage............................
Sonetpro wrote:madjack wrote:Steve, I have been meaning to ask...what didja do about about condensate drainage............................
There is a condensate drain in the back of the unit I put a hose on it going to the a hole in the floor. I put a screen on the end of it to keep mud dobbers and bugs out.
Dooner wrote:Steve,
Sorry if I missed it, but where are you getting the cool intake air for the condensor? I see the exhausts (I asume) on the side.
And sweet looking install there. How has it been working for you? Have you had any problems?
