Foam Nozzle
Foam Nozzle
Postby Jack55 » Wed Feb 17, 2016 12:02 pm
I saw this on YouTube then checked out the web page. It's just a nozzle that you put on a can of great stuff, or other foam sealant, and it spreads out the foam as you lay it down. Looks like it might work well in some instances for foaming around the curved section, where you have to kerf the foam. If your design allows perhaps this could be used in lieu of the foam sheet. Anyway, I don't know the guy nor do I have any interest in the product, I just thought I'd throw it out there. He sells it on eBay for seven bucks. http://www.eznozzle.com/video-how-to-use/
Jack55 " We are too soon old and too late smart."
Jack55
Re: Foam Nozzle
Postby vegask » Fri Feb 19, 2016 4:02 pm
Thank you for this, I just ordered a set from him.
vegask
Re: Foam Nozzle
Postby mallymal » Sat Feb 20, 2016 11:44 am
Just wanted to say a massive thank you for finding this product. Great idea, and opens up all kinds of possibilities for insulating the walls... Especially with a cookie cutter hollow wall design, where you might not be able to get rigid foam the right thickness. Great find :thumbsup:
mallymal
Images: 18
Re: Foam Nozzle
Postby Jack55 » Mon Feb 22, 2016 7:39 am
I thought it might be of interest to someone. Another one of those "why didn't I think of that" ideas, that I didn't think of!
Jack55
Re: Foam Nozzle
Postby vegask » Mon Apr 04, 2016 6:22 pm
Ordered a set of 8 off of ebay, they were really cheap. So on saturday I used a total of 4 cans of the cheap "red can" spray foam that is on every end-cap at Homedepot.
Really impressed with it, went on very easy. 30 min after application the foam was exactly 1.5" thick and was dead even with my roof spars... Then, 30 min later it grew another 1/2" later so I am off to get a large saw blade to start trimming down the excess. Anyways, not a bad option for insulation.
right after the 3rd can was empty.
about an hour after the 4th can was used
Gonna touch the area up around the wires once electrical is done.
vegask
Re: Foam Nozzle
Postby Specktre » Tue Apr 12, 2016 8:38 pm
why I did not see this before :cry:
At least I will be able to use that for my galley hatch :applause:
Thanks for the share and picture
Specktre
Re: Foam Nozzle
Postby vegask » Wed Apr 13, 2016 11:02 am
Specktre wrote:why I did not see this before :cry:
Just one note, wait 24 hours before trying to trim it, I ruined the blade on my pull saw by going to early, got covered in sticky foam goo... Ended up using the blade from a 21" tree saw that harbor freight sells ($6) and it worked great.
vegask
Re: Foam Nozzle
Postby KCStudly » Wed Apr 13, 2016 1:14 pm
Cleanup is easy with acetone (wear disposable rubber gloves).
Re: Foam Nozzle
Postby skyl4rk » Wed Apr 13, 2016 8:24 pm
Does that foam absorb water?
skyl4rk
Re: Foam Nozzle
Postby rowerwet » Mon Apr 18, 2016 10:21 am
Yes it does
rowerwet
Images: 521
Re: Foam Nozzle
Postby vegask » Mon Apr 18, 2016 2:09 pm
They claim it does not, but from experience it can absorb water. Especially the areas that you shave the outer edge off. I am not that worried, I live in the desert and if water gets in there I probably have much bigger problems.
vegask
Users browsing this forum: No registered users and 23 guests
