7x16 Conversion from Georgia
Re: 7x16 Conversion from Georgia
Postby flboy » Thu Aug 11, 2016 1:20 pm
Hi Martin. Did you get your AC framing done? I hope it is coming along well.
Sent from my SM-N900P using Tapatalk
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby m.colley » Thu Aug 11, 2016 6:25 pm
flboy wrote:Hi Martin. Did you get your AC framing done? I hope it is coming along well.
Hey Don,
Not yet I haven't. I hope to have my AC this coming week, then I'll start on it. I wanted to have the AC on hand to measure before I started cutting holes. My plumbing is almost finished, I got started cutting the hole for my outside shower box that I'm hacking for my tankless water heater hookup and it started pouring rain. I'll have all the plumbing done before the weekend is over, then it on to the AC, then the bed. If I'm lucky I'll have it all done by first of September.
Martin
m.colley
Images: 83
Postby lrrowe » Thu Aug 11, 2016 7:46 pm
Hey Don,
Martin
Martin, that is an interesting comment about waiting for the actual AC unit and measuring it before you start the framing. When I recently moved my AC unit to a false wall and cut the hole, I wondered what kind of modifications will I have to make to it in the future when this unit dies and I have to get a new one. Will the new unit require a larger opening or will I have to fill it in (not likely). For builders like yourself, when if you build cabinet type framing, how are you allowing for this contingency?
Bob
lrrowe
Images: 439
Postby m.colley » Fri Aug 12, 2016 5:28 am
Hey Bob
What I've found out over the years is that most AC's follow a universal (or close to it) size guideline. For example most 5000 BTU AC follow a given size. In my research a 6000 and 8000 from the manufacturer I'm buying from are identical size. Worst case scenario is I'll have to do a picture frame type trim ring to hide gaps.
Martin
m.colley
Images: 83
Postby lrrowe » Fri Aug 12, 2016 12:26 pm
Thanks Martin, that is good to know.
Bob
lrrowe
Images: 439
Postby flboy » Fri Aug 12, 2016 7:57 pm
lrrowe wrote:Thanks Martin, that is good to know.
Bob, I have extra room on my shelf for a larger AC or smaller. The way mine is installed, I may have to cut a few new foam pieces to seal off the inputs and outputs. On the Front Panel (When I build it for this one), I am going to cut it for a close fit on this AC and a replacement is smaller for some reason, then I'll do what Martin is recommending. If it is larger, I will just modify the panel as needed. In all cases, it should be relatively easy.
I'd cut your panel tight for the first AC. You can always cut more off for a larger one... and add trim for a smaller
Martin, I hope you get that AC installed soon. It is a hot one this summer!! I have been firing mine up just to work inside the trailer. It is nice. :-) I wired up the Fridge this week. Now I have cold drinks in there too. Heck, by the end of the weekend, I'll be able to use the toilet... :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Postby m.colley » Fri Aug 12, 2016 8:41 pm
Thanks Don, same here. I've managed to be able to work using a squirrel cage fan I salvaged from a old indoor AC air handler and a redneck AC unit ( a cooler with air intake and frozen water bottles). If I could keep the ice frozen long enough I'd seriously think about forgoing the AC unit install for now. ;) Your right about the heat, until this week, when the rain started moving up from down your way, we had 42 straight days of 92+ degree weather, and several 96-99 degree days. Right now we're in the middle of a cold spell. The past several days we're lucky if we hit the mid to high 80's :lol:
Martin
m.colley
Images: 83
Postby m.colley » Thu Aug 18, 2016 8:14 pm
The late afternoon rain storms finally let me get my plumbing and electrical done. The front end is done. I went back thru all my electrical and verified that everything works and that the PD4045 is working, charging batteries etc. Here's a pic or two of what the finished front/Vnose end looks like.
144044
144045
I do have a couple of USB receptacles on the way that will go just above the battery disconnect switch. I plan to use them to charge cell phones and a tablet. Now that the plumbing is done I hope to start the framing for the fold up bed frame and the metal frame work for the AC that I plan to bring home tomorrow.
Martin
m.colley
Images: 83
Postby flboy » Fri Aug 19, 2016 10:03 pm
Martin, that really looks nice! Great work! :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Postby m.colley » Sat Aug 20, 2016 3:29 pm
Here's a couple of pictures of my plumbing setup for my tank-less water heater hookup. I took a outside shower box and mounted it, gutting the shower setup. I installed a couple of faucets meant for hooking up a washing machine.
144090
Inside my hook up looks something like this.
144092
The gate valve will let me shut off the flow of cold water to the tank-less water heater in the event its not hooked up outside. That way I'll still have cold water to the sink faucet if needed. I plan to hang/install the tank-less just above the city/gravity water inlet.
144091
Six foot long hoses will give me plenty of height above the inlet/outlet box. I'm waiting for the water heater before I decide what kind of mount to make for it. I know they advise it to have two inches of space between the backside of it and its mounting surface. I'm thinking I may use two thick pieces of unistrut channel spread across two wall studs to hang it from. We'll figure that out once it gets here.
Martin
m.colley
Images: 83
Postby m.colley » Sat Aug 27, 2016 8:00 pm
I opened up the ramp today to start my framing for the AC install. I removed the plywood from the inside, and removed the metal from the exterior, exposing the metal framing.
144323
m.colley
Images: 83
Postby flboy » Sat Aug 27, 2016 8:32 pm
m.colley wrote:I opened up the ramp today to start my framing for the AC install. I removed the plywood from the inside, and removed the metal from the exterior, exposing the metal framing.
No turning back now... that looks like commitment! Best of luck with that. I look forward to seeing the finished product. :thumbsup: :thumbsup:
Don (Flboy)
flboy
Images: 378
Postby m.colley » Sat Aug 27, 2016 8:39 pm
Hey Don,
I actually got it framed in. I was in the middle of posting pictures and lost my internet connection :x , guess I'll finish it up now lol.
Martin
m.colley
Images: 83
Postby m.colley » Sat Aug 27, 2016 8:49 pm
144323
I decided I wanted to do as little cutting as possible so I elected to cut the center 1x1 1/2 and frame in between the left and right metal stud.
144319
I dropped down 5 inches from the bottom of the top framing member and then dropped down again to 21. Since I'm using 16 gauge 1x1 square tubing, that leaves me a 14 inch opening. My AC unit is 13 1/2 inches tall at its deepest point so I have a little wiggle room.
I marked the center point in the opening and cut my two side framing pieces, leaving myself a 19 1/4 inch opening, the AC unit is 18 1/2 inches wide.
144321
I tacked everything in place and then started running beads on all my joints.
144321
And then it was done.
144322
Tomorrow I'll reinstall the metal and inner plywood and cut the opening through both pieces. I'll have to shim the inner plywood around the framing I installed since I was using 1x1 and the factory used 1x 1-1/2 but that's no big deal. Once that's done I'll start on my support rack. I hope to have it finished up by tomorrow evening. Stay tuned.
Martin
m.colley
Images: 83
Postby m.colley » Sun Aug 28, 2016 6:25 pm
The hole for the AC is done.
144335
I reinstalled the plywood, insulated the insides, pre-drilled some holes for later use and reinstalled the siding.
144336
I installed the 1-1/2x 1-1/2 perforated angle that will be used to support the tray/rack the AC will sit on using the holes I predrilled earlier.
And here it is, ready for me to build the rack and support.
144337
Martin
m.colley
Images: 83
