Hello guys i thought it was time to share my build. Been reading on here for awhile now and got a lot of great ideas.I wanted something with high ground clearance for taking on hunting trips and offroad trails. The trailer is pretty much complete now but i took pictures along the way, let me know what you think and if anyone has questions id be happy to answer. Bare with me as i stumble my way through posting on the forum. Here is the trailer steel layout. outside dimensions are 5x8 made from 2''x2''x 3/16'' square tubing.
I liked the look of the Hiker trailers so i tried to make it look similar.
all closed in.
picked up a used rv door that was laying out behind a shed for 50$, cut it down to size. Worked out great, even has the screen door. sorry the pictures look a bit squished, still getting the hang of this.
Picked up an suburban Nt-20 furnace for $80 a bit overkill on heat but the price was right and apparently it had never been used. Tested it out and it works amazing. More to come on the furnace later as i am still finishing it up.
Got some painted aluminum sheeting for the skin, i forgot to take pictures before but i painted the wood with a couple coats of sealer before applying the aluminum
rsz_20160504_194323[1] (1).jpg (83.39 KiB) Viewed 3610 times
installed 6 pin trailer plug for passing the power from the battery box into the trailer, 2 pins for 12 volt, 2 pins for 120 volt and 2 for thermostat wires for the furnace.
4 inch marine ports installed and diamond plating trim that i had custom bent for the upper corners
jnelson wrote:installed 6 pin trailer plug for passing the power from the battery box into the trailer, 2 pins for 12 volt, 2 pins for 120 volt and 2 for thermostat wires for the furnace.
Whoa, what's the rating and gauge on that wiring that you're passing 120v through? Is that just a standard 12v harness?
its a 14/6 wire and the plug is rated for 15 amps. Nothing major powered off it just a small led tv and phone chargers. Its been working with no issues, my friend is an electrician and he didn't see any problems with it.
