![Wink ;)](./images/smilies/econ_wink.gif)
We have used the more common Minwax poly , and it works Great but is a bit Pricy for our intentions and is somewhat “thin" out the can ... JMHO
GPW wrote:J’ I’d think whatever is cheaper , and oil based .... Interior means it doesn’t have any UV additives for outside use , thing is , it will be working for you Inside the wood ... I would think screw holes should be pre drilled and painted with the mix to get down into the threads, and we always use beeswax to coat the screw before inserting ... Helps the screw go in and adds a bit more waterproofing ... “ sealing “ wax so to speak ...![]()
In our legendary Humidity, if we forget a step it always comes back later on to bite us in the woodworking dept. ...
