Hello,
I am building a 9 foot camping trailer for hauling behind my 4 x 4. It will have dual batteries and propane tanks for long term off road usage. The wiring has been run and is kept in a sub floor. I need to hookup properly the propane lines to connect for the cabin heater, the cooktop and refrigerator. I have waited now 5 months for professionals to come and help me with this, nobody has appeared and I realize I must learn how to do this properly, if for no reason other then my own safety.
I was told to mount the propane line inside steel tubing for safety, which I can do. I am told of steel lines and copper which need to be flared, and the tool to do this correctly is costly. I am told about forged steel nuts that won't crack under strain. I also had a reference for flexible lines, but its frustrating when nobody around here seems to have any expertise in this area and the propane dealers are obviously too busy.
I need to run the line, then finish the plywood body, before attaching the vented box up front that will hold the propane tanks, batteries etc.
Thank you for your attention in this matter.
Gene So
