For the walls I am using a 3/4" plywood base sandwiched between a 1/4" interior skin and a 1/8" exterior skin.
The standard 8' plywood sheet is just a hair short of my 9.5' requirement, so I had to stitch two sheets together. I did a really simple butt joint with pocket holes. I know there are stronger methods using splines, but the theoretical build in my head will be good enough to hold up. The strength of the joint should come from the sandwiching of the outside skins
We decided to cut out large sections of the 3/4" plywood to lighten the wall assembly and to allow for insulation. This was really fun to plan out. I wanted to make sure important structural points had enough meat left in the wall for mounting, but still trim the fat enough to make it worth while.
For the profile arc I built a router compass out of 1/4" Plexiglas. This allowed me to get a nice smooth curve with no additional sanding required. it was surprisingly easy to put together. The front arc is a simple 30" radius positioned 1.5' from the bottom edge of the wall and 30" from the end of the sheet. The galley arc is a combination of a 47" radius and a 30" radius.
Once the first wall was completed I traced the outlines onto the second wall and rough cut it with the jigsaw. Then I used a flush trim bit in the router to "photocopy" the first wall and ensure both were identical.
I think the result is a nice overall profile. The wifey likes it and that's all that matters. I couldn't resist propping the wall up on the trailer.
The final assembly has a 5" relief cut along the bottom to create a rabbet joint to the floor.
Cutting the insulation was as easy as tracing the walls then cutting with a utility knife. And check out that big ole' door!
