so I am good with going under the bed once a trip or so
Shadow Catcher wrote:The one thing you need to check above and beyond state of charge in a conventional Lead Acid is water level, mine is AGM so not an issue but it is something you need to do and add distilled water.
tony.latham wrote:so I am good with going under the bed once a trip or so
Just wire in a voltage meter and eyeball it after your battery has been at rest for a half hour or so:
https://www.amazon.com/ZJchao-zjchao030 ... B00JUI7VW8
(Just one example)
They pull so little amperage that it won't draw your battery down.
Graniterich wrote:tony.latham wrote:so I am good with going under the bed once a trip or so
(Just one example)
My experience was that these due drain down, best to install a switch.
bdosborn wrote:I check mine quarterly when the trailer is in storage, monthly if I'm camping a lot.
Users browsing this forum: Google [Bot] and 14 guests
