Woody Teardrop Kit Some assembly required
Re: Woody Teardrop Kit Some assembly required
Postby Woodpecker » Mon May 08, 2017 1:43 pm
Got the bed shelf in Friday. Finished the electric off this morning.
We added a dual USB port in next to the 12v lighter socket.
148191
Wet, rainy weekend. Couldn't work on the Woody but I did get the new drum finished!
148192
I make these out of propane tanks. It's where I get my daily spending money.
And I use the left over steel for Combat Robots.
Woodpecker
Images: 186
Postby Woodpecker » Thu May 11, 2017 9:56 am
Nasty weather for working outside so far this week.
Still getting 'er done.
Routed and mounted the hatch hinge brace board.
Finished the interior roof skin and the hole for the vent fan.
Finished the rough wiring & insulation.
Finished the closet cleating, gotta get a new piece of shelf wood. I messed up a cut earlier in the build.
You can see 95% of that in one pic.
148239
Woodpecker
Images: 186
Postby Woodpecker » Tue May 16, 2017 1:27 pm
Rain, rain, rain.
Still plugging away!
Rough trim is done on one side, 75% on the other side.
148341
Woodpecker
Images: 186
Postby VT800C » Wed May 17, 2017 1:37 pm
Lookin' MIGHTY fine!
8)
VT800C
Postby Woodpecker » Mon May 22, 2017 7:34 pm
Thanks 8)
Got one side trim all sanded, routed, stained, glued, screwed, pegged and sanded again. Ready for final stain and varnish! Man that trim is a job.
148417
Woodpecker
Images: 186
Postby Woodpecker » Fri May 26, 2017 11:05 am
One side stained and ready to varnish.
148438
Woodpecker
Images: 186
Postby Woodpecker » Fri May 26, 2017 1:54 pm
Done for the day. Got the second side all sanded and routed.
148442
Gotta hang the door to verify the fit then stain the trim and glue it down.
148443
Woodpecker
Images: 186
Postby Woodpecker » Tue Jun 13, 2017 4:20 pm
Crazy busy but still plugging away!
Trim on, doors finished and mounted.
Locks mounted.
12v electric fuse panel in, ditto the rest of the cabin lighting and the outside door light. All nice LED fixtures.
Most of the 110 v done. I'll mount the receps in after the rest of the wood is varnished.
Happy to see both sides done on the outside except for 2 more coats of varnish.
That trim is beautiful but a real PITA!
148740
148741
Have to finish the inside closet then start on the galley and skinning the roof.
Woodpecker
Images: 186
Postby Woodpecker » Mon Jun 26, 2017 11:07 am
Got the Galley shelves started.
Cooler or fridge fits in the slot to the left.
149200
First cut for the Bustle wings jig.
Gonna look at it a minute before deciding.
149201
I'll get a pic without the plastic blocking the view.
Woodpecker
Images: 186
Postby Woodpecker » Mon Jun 26, 2017 11:47 am
I cut the wing down 2" and I like it.
149202
This will give a 14" x 3' counter on each wing.
Woodpecker
Images: 186
Postby Woodpecker » Tue Jun 27, 2017 1:15 pm
Got the Removable Butcher Block Counter top ready for the 10 day long sealing process.
The cleats are screwed but not glued in case the future owners want to customize here.
Very few screws are left uncovered on this TD but they are easily accessible on the cleats.
Lots of room for a cooler or a fridge. Propane tank should fit under the center counter. Gotta double check it but the plan says it will. :worship:
149208
Woodpecker
Images: 186
Postby tac422 » Tue Jun 27, 2017 2:44 pm
I'm curious about the "Drum".
How do you make them ?
tac422
Postby Woodpecker » Wed Jun 28, 2017 8:38 am
tac422 wrote:I'm curious about the "Drum".
Morning =)
I usually use an old Propane tank that has seen it's usable service life ended.
That means pulling the valve, filling it with water and letting it sit overnight at least.
Then I cut the ends off and grind, smooth, sand and paint them with primer.
Black primer inside, grey outside. Then a quick sand off the paint from the edges where I have to weld.
149209
I give it a hot weld with the MIG then a smoothing with a flame torch and then a good grind and sand.
149210
That makes a nice shell, I mark the keys on it and cut them with a jigsaw and tune them with a file.
149211
A little paint and it's a drum.
149212
149213
Buy them as I build them and they are $150 plus shipping.
Custom orders/ key of C of F or paint style & colors available.
I use the leftover sleeve of steel for my "Mechalodon" Combat Robots.
149214
In fact selling the drums is what pays for me to build my robots lol.
Woodpecker
Images: 186
Postby Woodpecker » Thu Jul 06, 2017 1:09 pm
We have wings! The first test fit is always a little exciting.
Perfect fit for the passenger side wing. The drivers side is still drying in the forming jig.
149413
Each wing gives an extra 14" x 33.5" of counter space.
149414
Woodpecker
Images: 186
Postby Woodpecker » Fri Jul 14, 2017 12:46 pm
Wings installed.
Great Line-up and really tight.
149864
They open up nice and the big gate hinges seem to be plenty strong.
149865
Have to pull them off and route the trim then I can screw them on for good.
Then on the hatch!
Woodpecker
Images: 186
Users browsing this forum: twisted lines and 21 guests
