pk4013 wrote:Was hoping you guys could help me with a fantastic fan problem. I wired the fan along with 2 12v lights, each has their own switch. Then wired into a PD4045 on one circuit with a 15amp fuse. The fan comes on but gets really slow then stops all together. Then it takes awhile to get it to come on again then it does the same thing. Wired with 14 gauge wire and separate grounds into a bus bar. Just the basic fan, 3 speed with reverse.
Iconfabul8 wrote:So did it work when you went direct to the other battery? If not I would say your fan has grief. If it did run fine direct to the battery, I would try running a ground jumper from the battery directly to the fan. Frame grounding can be iffy sometimes.
pk4013 wrote:I just took the motor out and hooked it up and nothing. I hit it a couple times on the concrete and it worked. Bad motor.
onehoser wrote:pk4013 wrote:I just took the motor out and hooked it up and nothing. I hit it a couple times on the concrete and it worked. Bad motor.
ah yes, the highly technical maneuver called 'removing latent motion', i do it all the time
