OCBINVA wrote:I was thinking I would wire in a reverse and speed control.
That's the way I would do it.
I used 3" PVC for ducting the bathroom fan.
That sounds interesting. Have any pics? I have been leaning to a bilge fan to this point. This is a micro camper and is my testbed for bigger and better things down the road.daveesl77 wrote:We use PC fans (140mm) and love them. We have a ducting system in the front of our camper with the ports located underneath. The ducts go from the very top of the camper to the bottom. Each duct has two fans (actually 3, but only 2 are for the cabin). Duct #1 brings fresh air into the camper. Duct #2 exhausts the air. No roof holes. Each duct is individually controlled. Since air under the camper is normally cooler than that in the sun, then the intake is cooler. Having the ports in the bottom, they are always open, but covered with a screened louver facing backwards. As we drive, the natural movement of air pulls air into the wiley windows and out through both ducts, without the fans running. The wiley windows never leak, even during Hurricane Irma.
One the other two duct fans, one is used to cool the dorm fridge and the other to cool the electronics station. Yes, 6 fans that are very, very quiet. Each uses 0.2amp at 12v. Each is rated at 60 cfm, but in reality it is probably about 30. So if all 6 are running we are only pulling 1.2 amp, total. Each section is individually controlled. The two equipment fans, the two intake fans, the two exhaust fans. Plus, on each wiley window we have a 10" O2 fan that can do further cooling.
For almost all PC fans, they cannot run in reverse. You can buy good ones for about $10 each. The O2 fans were about $20. Most nights we can just turn on the exhaust duct and it is fine.
dave
Standard RVs are very build very shoddily. To me the whole point of DIY is getting it right, building something far better than anything off the shelf.Hader wrote:shortcomings of 'Typical' RVs. The last thing we'd want is to build an RV-like trailer.
