"NotJammer wrote:Got a Kill a Watt checking 120 VAC consumption. On startup, it pulled 44 watts and now on Engel recommended setting 3 of 5 it pulls 36 watts 120 VAC. Can't check 12 VDC yet."
Watts are watts.....
" This CTC may be used a Film Darkroom, so I want complete blackout. The 2 windows will get Dark Slides, which are black Coroplast https://www.homedepot.com/p/24-in-x-36- ... /205437929 It weighs nothing and will slide in and out of ruler slats screwed into the wall. I know this will be good enough for well-lit campgrounds, moon, and stars but may not work for full Sun. No big deal I can use the Darkroom at night.
I'm an old-time camera nut and may put a porthole in my CT so the whole thing is a camera obscura. https://www.wired.com/2017/05/ian-kasno ... ox-camera/
Which anybody can do and just sit inside and look the image. That's fun too. Any TD or CTC will work if you can make it very dark inside. You don't even need a lens. Just a small hole! Ask me if interested.
Been there, done that.
No windows, only 180deg peepholes mounted N,S,E AND West walls, Helps with stealth and privacy as well.
McDave
