Maybe throwing gasoline on a fire but I would advise against any dimmer that uses pulse-width-modulation for dimming. Even if you aren't sensitive to the flicker, other people near you and wildlife are. claimed (accurate or not) 10khz still registering the nervous system even if not consciously detectable. For 12v LEDs you can dim them by dropping the voltage being fed, depending on the specific elements most will light starting between 3 & 5 volts. A voltage controller will cost more than a PWM dimmer but is a much more responsible method. If you're on a tight budget like i was, wire in smaller separate LED panels/strips each on their own switch. This can give you a reading light on each side and/or a vent light with multiple steps of brightness and better power efficiency.
I did my vent light in 2 steps so it's either 1/2 or full brightness depending on one or two switches being on but if you want more control you could easily do more element-switch pairs just don't blind yourself with too much light.
![156126](http://tnttt.com/gallery/image.php?mode=thumbnail&image_id=156126)
The third switch turns the thermostat on and off.
