Dahlia47 wrote:For the harbour freight generator, how long will I be able to run the little window a/c unit?
And what does it mean when the description says "running at 50%?
I don't know anything about electricity or engines. I can make just about anything out of metal and wood, but when it comes to electricity and engines, I am so lost! Ugh!
Thank you!
booyah wrote:So close to sea level I've been able to run a 5000BTU off a small 8-900w 2 cycle generator like this one
https://www.harborfreight.com/900-max-s ... 63024.html
Down side is its dirty, loud, pretty close to max load, and smells (2 cycle)
More recently I've been using this one
https://www.amazon.com/WEN-56200i-2000- ... 00SMNLF4M/
Quieter, cleaner, plenty more power, and not as stinky.
I'd love to see if this guy can run a 5000btu AC though
https://www.homedepot.com/p/RYOBI-900-S ... /302703564
All the nice clean, quiet, happiness of the bigger genny, but runs off propane (NO GAS!) and is smaller than the 2 cycle guy.
thing is he's a little bit expensive to spend on an experiment, especially when I already have two small generators.
Pinstriper wrote:
I'd love to see if this guy can run a 5000btu AC though...I have that Ryobi, but I don’t have a 5k AC to rest with. I’m gonna go ahead and say “doubtful”...
Pinstriper wrote:Do the specs show the surge load it draws ? Could be as much as 3 times running load. Even twice the load would be iffy.
Aguyfromohio wrote:Pinstriper wrote:Do the specs show the surge load it draws ? Could be as much as 3 times running load. Even twice the load would be iffy.
I looked and can't find a number for this unit for in-rush current during start-up. I found do-it-yourself test runs with clamp on meters showing 200%, and others on forums claiming 150%.
Need to test to figure it out I guess.
