Forecast is for 44C (111F) today.
It was only 42 yesterday.
I should be sitting at my desk sorting out receipts and things, getting ready to dump the whole shoe box on my accountant's desk so we can file my tax return.
Or, I could be taking advantage of the hot dry weather to wash the carpets.
Suppose I could load the dog in the ute and take him down to the beach for a swim.
Maybe that'd knock some more loose hair out of his coat and reduce the need for carpet cleaning.
Instead, I'm sitting here looking at the generic Benroy plans.
The plans call for a 19 inch radius at the front, and the same at the rear to smooth out the transition from curved to straight at the rear.
The 4mm marine ply I can buy locally is hardwood, and looks really inflexible. I expected to at least flex it easily in the rack at the shop, but got a bit of a shock at how stiff it is.
Will it bend a 19inch radius without cracking?
Should I increase the radius to 24 inches, to give myself a better chance?
Given the tear will be closer to 9 feet long than 8 feet, would there be an unacceptable loss of head room at the front?
Should I do away with the 19mm radius at the rear and just use a single radius a bit shorter than 48 inches?
Trouble is - I like the Benroy profile as drawn.
I really like this
viewtopic.php?f=50&t=29535&start=214If my camper comes out as nice as caseydog's I'll be very happy.
He used some sort of skinning material he got from Home Depot. It appears to have been dead simple to bend around any radius you choose, and the visible screws look cool to me.
That material ain't gunna happen here. I've never seen a Home Depot in Australia.
I
have found a place interstate that sells fibreglass sheet off the roll.
Choices 1.5mm, 2.0mm and 2.4mm thick.
I'd go for 2.0 or 2.4mm thickness.
Price isn't significantly higher than plywood.
Just gotta persuade them that "pickup only" is too hard for me - and negotiate a freight option.
If anyone for South Australia knows of a source in this state I'd like to hear of it.
I've tried a couple of caravan places in Adelaide and the repair guy in Port Wakefield, no joy.
