kscmpr54 wrote:As I look at axles, there are straight with leaf springs, cambered with leaf springs and torsion.
working on it wrote:
- I don't agree that a leaf spring axle is too "bouncy" to ride right, and that only Timbren axles, or torsion axles are the way to go. I like, trust, and have easily repaired leaf spring axles, before, and wouldn't write them off to history, as being out-dated or incapable for light or heavy use. with a little planning or modifications, you can tailor leaf springs for any road condition.
- As I stated before, earlier in this thread and in others, I stayed with leaves on my last trailer mod/upgrade, when replacing my original axle and springs (overloaded spindly axle of unknown capacity) with a Dexter 3500 lb axle w/brakes. I replaced the original equipment with off-the-shelf springs from Northern Tool. I bought the 3000 lb (a pair, sold individually) springs, because I knew I was loading my trailer heavier with each trip, and modification, and was pretty sure it would weigh more than 2000 lbs eventually. I would've preferred a 2500 lb rating, but they didn't offer a rating in between 2-3k lbs in the size/type I was using, I got the 3000 lb set which has worked pretty well, so far.
- Since my previous spring set had a shackle tear loose from the frame. I reinforced the frame rails with 1/4" angle, boxing in/ covering over the trailer frame, I opted for all new hardware. New leaf springs and all the associated hardware are easy to come by in North Texas, and I chose to stay with leaf springs due to ready availability everywhere, and standardization of the hardware making repairs easy to do. I previously had another trailer spring problem, on my tandem trailer, which I had grossly over-loaded with engine blocks and heads, breaking one spring when it over-flexed (used a ratchet strap, 5000 lb rating, to secure the broken end). I replaced it in a parking lot near the Redneck Trailer Supply that I passed on my way home, where I got a replacement spring. Later on, I replaced much more hardware, worn and rusted out, on that trailer in 2007, when I replaced both axles with new Rockwell-American axles (each 3500 lb w/brakes), at a friend's shop near Azle, where there is another ready source for spring axle parts.
- I added an oversized, progressive, bumpstop (modified to fit between axle and frame, with no gap), to serve as a means to soften hard jolts, and prevent the springs from over-flexing (which tore loose the shackle on my TTT, and broke the spring on my tandem trailer). I tried it as an experiment, in lieu of using shock absorbers, or air bags, or Timbren airless springs. Since I made my own "active airless suspension", I see that Timbren makes their own version, which wasn't made back in 2014, when I made mine.
- vs homemade, earlier version
- It works very well, proving itself when it protected my springs from breakage, when my trailer flew after hitting a major pothole at 75 mph (so bad that it caused belt separation in three of my truck tires, 10 ply, on my Chevy 2500 HD). I haven't taken it off-road yet, but I think it will serve well there, too, and if too harsh, then I can adjust the bumpstop by cutting the center ligament, and make it more compliant. IMHO, leaf springs are more easily repairable/cost effective/modifiable than the alternatives.
Thank you for the additional perspective Working On It. Lots to consider.working on it wrote:* As a counterpoint, here's my case for using leaf springs, from an earlier thread http://www.tnttt.com/viewtopic.php?f=39&t=66773&hilit=dexter+axle&start=15#p1223878working on it wrote:
* P.S. like Noseoil, I believe that using larger tires is better overall, than smaller diameter ones, for the same reasons. And further, using passenger-car radials on lightweight teardrops is OK, but for heavier, possibly off-road trailers, LT tires are better than using may-pop "Chinesesium" ST tires. My TTT uses 14" LTs.
