QueticoBill wrote:For a typical teardrop roof - like a 4' or 5' wide - am I the only one that thinks kerfing makes more sense?
Pmullen503 wrote:The problem with heat forming foam, and I've done a lot of it, is the temperature that foam becomes flexible is very close to the temperature that it collapses. That and the need to let the heat "soak" in means you need good temperature control and the ability to hold it there for a long time.
I've been able to heat form foam for RC planes into complex curves but I'm typically working with foam only 1/4" thick. I think I could do 1/2" with the right time and temperature settings. At that point you could laminate several layers to get a usable thickness.
The equipment to do this is more than most one-off builders would want to invest in, but it could be done.
ghcoe wrote:QueticoBill wrote:For a typical teardrop roof - like a 4' or 5' wide - am I the only one that thinks kerfing makes more sense?
I will still be kerfing my builds.
Kerfing in my opinion is so much easier and takes less time. Of course I do have a hot wire jig that makes it simple.
